[petsc-dev] Dependency problem: Sys depends on DM when Sieve is enabled
Wed Dec 21 08:57:17 CST 2011
On Wed, Dec 21, 2011 at 08:54, Matthew Knepley <knepley at gmail.com> wrote:
> Same intention as what we are doing now, so just remove this file from the
> build.
By that, do you mean move it to src/dm or that the code is unused and could
be deleted?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111221/8cbe3beb/attachment.html>
