[petsc-dev] Seeking Advice on Petsc Preconditioners to Try
Tue Dec 20 09:41:20 CST 2011
On Tue, Dec 20, 2011 at 09:33, Dave Nystrom <dnystrom1 at comcast.net> wrote:
> Hi Mark,
> I would like to try GAMG on some of my linear solves.  Could you suggest
> how
> to get started?  Is it more complicated than something like:
> -ksp_type cg -pc_type gamg
Sure, start with this.
> I'm guessing I should first try it on one of my easier linear solves.  I
> have
> 5 of them that would have a block size of 1.  Are the other GAMG option
> defaults good to start with or should I be trying to configure them as
> well?
> If so, I'm not familiar enough with multigrid to know off hand how to do
> that.
What sort of problems? The defaults should be reasonable for elliptic
problems.
> Thanks,
> Dave
> Mark F. Adams writes:
>  > >> It sounds like you have a symmetric positive definite systems like
> du/dt -
>  > >> div(alpha(x) grad)u.  The du/dt term makes the systems easier to
> solve.
>  > >> I'm guessing your hard system does not have this mass term and so is
>  > >> purely elliptic.  Multigrid is well suited for this type of problem,
> but
>  > >> the vector nature requires some thought.  You could use PETSc AMG
> -pc_type
>  > >> gamg but you need to tell it that you have a system of two
> dof/vertex.
>  > >> You can do that with something like:
>  > >> ierr = MatSetBlockSize( mat, 2 );      CHKERRQ(ierr);
>  > >> For the best results from GAMG you need to give it null space
> information
>  > >> but we can worry about that later.
>  > > Hi Mark,
>  > > I have been interested in trying some of the multigrid capabilities in
>  > > petsc.  I'm not sure I remember seeing GAMG so I guess I should go
> look for
>  > > that.
>  > GAMG is pretty new.
>  > > I have tried sacusp and sacusppoly but did not get good results on
>  > > this particular linear system.
>  > > In particular, sacusppoly seems broken.  I
>  > > can't get it to work even with the petsc
> src/ksp/ksp/examples/tutorials/ex2.c
>  > > example.  Thrust complains about an invalid device pointer I believe.
>  > > Anyway, I can get the other preconditioners to work just fine on this
> petsc
>  > > example problem.  When I try sacusp on this matrix for the case of
> generating
>  > > a rhs from a known solution vector, the computed solution seems to
> diverge
>  > > from the exact solution.  We also have an interface to an external
> agmg
>  > > package which is not able to solve this problem
>  > > but works well on the other 5
>  > > linear solves.  So I'd like to try more from the multigrid toolbox
> but do not
>  > > know much about how to supply the extra stuff that these packages
> often need.
>  > > So, it sounds like you are suggesting that I try gamg and that I
> could at
>  > > least try it out without having to initially supply lots of
> additional info.
>  > > So I will take a look at gamg.
>  > There are many things that can break a solver but most probably want to
> know that its a system so if you can set the block size and try gamg then
> that would be a good start.
>  > Mark
>  > > Thanks,
>  > > Dave
>  > >> Mark
>  > >> On Nov 30, 2011, at 8:15 AM, Matthew Knepley wrote:
>  > >>> On Wed, Nov 30, 2011 at 12:41 AM, Dave Nystrom <
>  > >>> I have a linear system in a code that I have interfaced to petsc
> that is
>  > >>> taking about 80 percent of the run time per timestep.  This linear
> system is
>  > >>> a symmetric block banded matrix where the blocks are 2x2.  The
> matrix looks
>  > >>> as follows:
>  > >>> 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
>  > >>> 1X X                     Y Y Y
>  > >>> 2X X X                     Y Y Y
>  > >>> 3  X X X                     Y Y Y
>  > >>> 4    X X X                     Y Y Y
>  > >>> 5      X X X                     Y Y Y
>  > >>> 6        X X X                     Y Y Y
>  > >>> 7          X X X                     Y Y Y
>  > >>> 8            X X X                     Y Y Y
>  > >>> 9              X X X                     Y Y Y
>  > >>> 0                X X X                     Y Y Y
>  > >>> 1                  X X X                     Y Y Y
>  > >>> 2                    X X X                     Y Y Y
>  > >>> 3Z                     X X X                     Y Y Y
>  > >>> 4Z Z                     X X X                     Y Y Y
>  > >>> 5Z Z Z                     X X X                     Y Y Y
>  > >>> 6  Z Z Z                     X X X                     Y Y Y
>  > >>> 7    Z Z Z                     X X X                     Y Y Y
>  > >>> 8      Z Z Z                     X X X                     Y Y Y
>  > >>> 9        Z Z Z                     X X X                     Y Y Y
>  > >>> 0          Z Z Z                     X X X                     Y Y Y
>  > >>> So in my diagram above, X, Y and Z are 2x2 blocks.  The symmetry of
> the
>  > >>> matrix requires that X_ij = transpose(X_ji) and Y_ij =
> transpose(Z_ji).  So
>  > >>> far, I have just input this matrix to petsc without indicating that
> it was
>  > >>> block banded with 2x2 blocks.  I have also not told petsc that the
> matrix is
>  > >>> symmetric.  And I have allowed petsc to decide the best way to
> store the
>  > >>> matrix.
>  > >>> I can solve this linear system over the course of a run using
> -ksp_type
>  > >>> preonly -pc_type lu.  But that will not scale very well to larger
> problems
>  > >>> that I want to solve.  I can also solve this system over the course
> of a run
>  > >>> using -ksp_type cg -pc_type jacobi -vec_type cusp -mat_type aijcusp.
>  > >>> However, over the course of a run, the iteration count ranges from
> 771 to
>  > >>> 47300.  I have also tried sacusp, ainvcusp, sacusppoly, ilu(k) and
> icc(k)
>  > >>> with k=0.  The sacusppoly preconditioner fails because of a thrust
> error
>  > >>> related to an invalid device pointer, if I am remembering
> correctly.  I
>  > >>> reported this problem to petsc-maint a while back and have also
> reported it
>  > >>> for the cusp bugtracker.  But it does not appear that anyone has
> really
>  > >>> looked into the bug.  For the other preconditioners of sacusp,
> ilu(k) and
>  > >>> icc(k), they do not result in convergence to a solution and the
> runs fail.
>  > >>> All preconditioners are custom. Have you done a literature search
> for PCs
>  > >>> known to work for this problem? Can yu say anything about the
> spectrum of the
>  > >>> operator? conditioning? what is the principal symbol (if its a
> PDE)? The pattern
>  > >>> is not enough to recommend a PC.
>  > >>>   Matt
>  > >>> I'm wondering if there are suggestions of other preconditioners in
> petsc that
>  > >>> I should try.  The only third party package that I have tried is the
>  > >>> txpetscgpu package.  I have not tried hypre or any of the multigrid
>  > >>> preconditioners yet.  I'm not sure how difficult it is to try those
>  > >>> packages.  Anyway, so far I have not found a preconditioner
> available in
>  > >>> petsc that provides a robust solution to this problem and would be
> interested
>  > >>> in any suggestions that anyone might have of things to try.
>  > >>> I'd be happy to provide additional info and am planning on
> packaging up a
>  > >>> couple of examples of the matrix and rhs for people I am
> interacting with at
>  > >>> Tech-X and EMPhotonics.  So I'd be happy to provide the matrix
> examples for
>  > >>> this forum as well if anyone wants a copy.
>  > >>> Thanks,
>  > >>> Dave
>  > >>> Dave Nystrom
>  > >>> phone: 505-661-9943 (home office)
>  > >>>      505-662-6893 (home)
>  > >>> skype: dave.nystrom76
>  > >>> email: dnystrom1 at comcast.net
>  > >>> smail: 219 Loma del Escolar
>  > >>>      Los Alamos, NM 87544
>  > >>> What most experimenters take for granted before they begin their
> experiments lead.
>  > >>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111220/6b8f066b/attachment.html>
