[petsc-dev] Building a serial version of petsc with sundials, hypre, scalapack, etc
Dave Nystrom dnystrom1 at comcast.net
Mon Dec 19 00:06:53 CST 2011
Several of the external packages that have been interfaced with petsc require
mpi.  Is there a way to build a serial version of petsc with these packages
and use stub routines for mpi?  I know there are fortran stub routines,
i.e. mpiuni, that I am using for my application which is currently serial.
But is there a way to have petsc build these external packages that require
mpi and use some serial stub routines?  I tried building petsc with several
of these external packages while using the --with-mpi=0 configure option and
the build process would always fail and tell me to download mpi.  I'm
interested in being able to do this since my code is currently serial.
Dave
