[petsc-dev] wtf
Mark F. Adams mark.adams at columbia.edu
Sun Dec 18 17:56:58 CST 2011
Barry, I just pushed with your code removed ...
On Dec 18, 2011, at 6:25 PM, Barry Smith wrote:
> On Dec 18, 2011, at 5:21 PM, Mark F. Adams wrote:
>> Barry, did you add:
>> #define foo 1
>> #if defined(foo)
>>   PetscFunctionReturn(0);
>> #endif
>> to gamg.c?
>   Yes. I accidently pushed the #define foo 1 line, you can remove that one line, sorry about that. I may have removed it in a later push.
>    Why did I add that horrible #if defined() stuff? So I could run tests with MatMatMultSym() on your matrices without running the more memory using and time consuming part of the example. I am determined to beat Hong's best on the symbolic part :-).
>> You seem to be the only recent person to touch this other than me.  Also, how can I view the history of a file?
>> I used
>> hg log gamg.c
>> to see that you modified this file.  Is there a way to see what you did?
>   Better to ask someone who knows how to do all that stuff then just me.
> Barry
>> Mark
