[petsc-dev] boomerAmg scalability
Thu Dec 15 13:55:14 CST 2011
On Thu, Dec 15, 2011 at 1:51 PM, Ravi Kannan <rxk at cfdrc.com> wrote:
> HI Mark,****
> Is this pc_type gamg  and/or '-pc_gamg_type pa' or '-pc_gamg_type sa'
> available for the release  (3.2) version. Can it be downloaded from the
> PETSc webpage?
Its there, but there are several bug fixes in dev.
> Also, do you know if this will scale better than the HYPRE’s  BoomerAMG?
Yes, it should.
   Matt
> Thanks,****
> Ravi. ****
> *From:* petsc-dev-bounces at mcs.anl.gov [mailto:
> petsc-dev-bounces at mcs.anl.gov] *On Behalf Of *Mark F. Adams
> *Sent:* Thursday, December 15, 2011 1:18 PM
> *To:* For users of the development version of PETSc
> *Subject:* Re: [petsc-dev] boomerAmg scalability****
> On Dec 15, 2011, at 1:56 PM, Matthew Knepley wrote:****
> On Thu, Dec 15, 2011 at 10:23 AM, Ravi Kannan <rxk at cfdrc.com> wrote:****
> Dear All,****
> This is Ravi Kannan from CFD Research Corporation. Recently, we are
> experimenting with the BoomerAMG preconditioner for some “stiff” CFD
> problems. In that regard, all the other standard solver-preconditioner
> combinations failed for the current CFD problem. The boomer is the only one
> which is able to provide with “converged” solutions.****
> We noticed that the scalability of this boomer preconditioner is really
> poor. For instance, even with a cell size of 2 million, we cannot scale to
> even 16 partitions (in contrast, the other solver-preconditioner
> combinations like the BI-CGS/BJacobi gave good enough scalability).****
> Are we missing something? Do we need to use a more latest version of
> boomer?****
> Have you tried -pc_type gamg in petsc-dev?****
> For gamg you also want to use MPIAIJ matrices and set the block size
> MatSetBlockSize(mat,3), for a 3D velocity field, for instance.  You can
> also try '-pc_gamg_type pa' or '-pc_gamg_type sa'.  "pa", for plain
> aggregation might be better for CFD problems.****
> Mark****
>   Matt****
> Thanks,****
> Ravi. ****
> experiments lead.
> -- Norbert Wiener****
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111215/a30d7536/attachment.html>
