[petsc-dev] controlling vector values while doing matrix free operations
Philip, Bobby philipb at ornl.gov
Wed Dec 14 19:34:43 CST 2011
Matt:
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Wednesday, December 14, 2011 5:15 PM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] controlling vector values while doing matrix free operations
On Wed, Dec 14, 2011 at 4:07 PM, Philip, Bobby <philipb at ornl.gov<mailto:philipb at ornl.gov>> wrote:
Hi:
When doing the following operation in PETSc using FD approximations to a  Jacobian vector product
J'(u)*a = [J(u+h*a) - J(u)]/h
Usually, we would put in F where you have J.
Actually this is taken from PETSc documentation so you may want to modify it. I normally do use F also.
is there a way for the user to specify that the entries of u+h*a cannot be negative for example?
Browsing the PETSc documentation it was not obvious whether I could do this.
You can do whatever you want in your F function, but you should really investigate SNESVI if
you have bounds on your variables.
I do indeed control F and u but I do not control h*a. This is determined by PETSc. Hence the possibility
exists that u+h*a is outside the domain of the function. This is what I would like to control. Being able to
check whether u+h*a lies in the domain of the function and then potentially modifying it so it does much
in the flavor of the LineSearchPost and PreCheck functions. Any suggestions?
     Matt
Bobby
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111214/fbd4c521/attachment.html>
