[petsc-dev] KSP rtol
Wed Dec 14 15:53:58 CST 2011
On Wed, Dec 14, 2011 at 3:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 14, 2011, at 3:13 PM, Mark F. Adams wrote:
> > On Dec 14, 2011, at 3:44 PM, Barry Smith wrote:
> >> On Dec 14, 2011, at 12:45 PM, Mark F. Adams wrote:
> >>> I have a nonlinear problem and am finding the the convergence test for
> the interior PETSc linear solver is apparently testing against the norm of
> the first linear solve (see appended).
> >>  No it is || r = b - Ax ||/|| b||   with a B in there if left
> preconditioned
> >>  It has nothing to do with the "first linear solve". Each linear solve
> is self contained and it does not use anything from a previous linear solve
> to determine convergence of a later linear solve.
> > Matts suggestion -ksp_converged_use_initial_residual_norm did the trick.
> >>> This is clearly not what anyone would want,
> >>   Why not?
> > OK, I should say I don't know why anyone would want this and if you pop
> a KSP into a nonlinear loop, which is a very common thing to do obviously,
> then you get behavior that is probably not what you want.  Namely, an
> approximate Newton where the outer nonlinear tolerance is much smaller than
> the inner linear tolerance.
>    I would think you would want exactly that. Why oversolve the linear
> system since it is "wrong" anyways"?
>   Actually with Newton it should really be setting the linear tolerances
> based on the progress of the Newton method, this is done via -snes_ksp_ew
> I would like to make that the default but this scheme is not robust and
> occasionally strange things might happen. I'd like it if someone could
> investigate using EW by default.
I spent a ton of time on EW (Eisenstat-Walker) for my thesis. You are right
that its just not robust, but version 2 is more
robust than version 1 in my tests. EW is just two possible implementations
for the Dembo-Eisenstat-Steihaug theory. I
think Trond has some additional ones that are stuck down deep inside his
bizarre optimization code. I would love to turn on
version 2 by default, but we need a better nonlinear test set to see what
happens. Maybe some fluids thing?
   Matt
>   Barry
> > Just my perspective.
> > Mark
> >>  Barry
> >>> is this the intended semantics?
> >>> Is there perhaps a method to reset rtol?
> >>> Mark
> >>> Picard iteration 0 max(resid) = 781020
> >>> 0 KSP Residual norm 2.499264167662e+07
> >>> 1 KSP Residual norm 6.330915810095e+06
> >>> 2 KSP Residual norm 1.856999435466e+06
> >>> 3 KSP Residual norm 3.967325725053e+05
> >>> 4 KSP Residual norm 9.037332775808e+04
> >>> 5 KSP Residual norm 1.826960320400e+04
> >>> Linear solve converged due to CONVERGED_RTOL iterations 5
> >>> Picard iteration 1 max(resid) = 727577 ------- Rate = 1.07345
> >>> 0 KSP Residual norm 6.885328126772e+06
> >>> 1 KSP Residual norm 2.150319244570e+06
> >>> 2 KSP Residual norm 2.297759417371e+05
> >>> 3 KSP Residual norm 3.321819214451e+04
> >>> 4 KSP Residual norm 4.155970071625e+03
> >>> Linear solve converged due to CONVERGED_RTOL iterations 4
> >>> Picard iteration 2 max(resid) = 486788 ------- Rate = 1.49465
> >>> 0 KSP Residual norm 2.987417661953e+06
> >>> 1 KSP Residual norm 5.046119985008e+05
> >>> 2 KSP Residual norm 3.882757664605e+04
> >>> 3 KSP Residual norm 4.106091678345e+03
> >>> Linear solve converged due to CONVERGED_RTOL iterations 3
> >>> Picard iteration 3 max(resid) = 137348 ------- Rate = 3.54418
> >>> 0 KSP Residual norm 7.285359985607e+05
> >>> 1 KSP Residual norm 9.132700545850e+04
> >>> 2 KSP Residual norm 6.834608381922e+03
> >>> Linear solve converged due to CONVERGED_RTOL iterations 2
> >>> Picard iteration 4 max(resid) = 25082.7 ------- Rate = 5.47582
> >>> 0 KSP Residual norm 1.207523847817e+05
> >>> 1 KSP Residual norm 1.286174706329e+04
> >>> Linear solve converged due to CONVERGED_RTOL iterations 1
> >>> Picard iteration 5 max(resid) = 5723.21 ------- Rate = 4.38264
> >>> 0 KSP Residual norm 2.211945822133e+04
> >>> Linear solve converged due to CONVERGED_RTOL iterations 0
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111214/7bb72626/attachment.html>
