[petsc-dev] KSP rtol
Wed Dec 14 14:21:13 CST 2011
On Wed, Dec 14, 2011 at 2:07 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Mark
> On Dec 14, 2011, at 1:57 PM, Matthew Knepley wrote:
> On Wed, Dec 14, 2011 at 12:45 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> I have a nonlinear problem and am finding the the convergence test for
>> the interior PETSc linear solver is apparently testing against the norm of
>> the first linear solve (see appended).  This is clearly not what anyone
>> would want, is this the intended semantics?  Is there perhaps a method to
>> reset rtol?
> This is the same discussion about what to use a ||r_0||. You might want
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPDefaultConvergedSetUIRNorm.html#KSPDefaultConvergedSetUIRNorm
     Matt
> -snes_view -ksp_view?
>   Matt
>> Mark
>> Picard iteration 0 max(resid) = 781020
>>  0 KSP Residual norm 2.499264167662e+07
>>  1 KSP Residual norm 6.330915810095e+06
>>  2 KSP Residual norm 1.856999435466e+06
>>  3 KSP Residual norm 3.967325725053e+05
>>  4 KSP Residual norm 9.037332775808e+04
>>  5 KSP Residual norm 1.826960320400e+04
>> Linear solve converged due to CONVERGED_RTOL iterations 5
>> Picard iteration 1 max(resid) = 727577 ------- Rate = 1.07345
>>  0 KSP Residual norm 6.885328126772e+06
>>  1 KSP Residual norm 2.150319244570e+06
>>  2 KSP Residual norm 2.297759417371e+05
>>  3 KSP Residual norm 3.321819214451e+04
>>  4 KSP Residual norm 4.155970071625e+03
>> Linear solve converged due to CONVERGED_RTOL iterations 4
>> Picard iteration 2 max(resid) = 486788 ------- Rate = 1.49465
>>  0 KSP Residual norm 2.987417661953e+06
>>  1 KSP Residual norm 5.046119985008e+05
>>  2 KSP Residual norm 3.882757664605e+04
>>  3 KSP Residual norm 4.106091678345e+03
>> Linear solve converged due to CONVERGED_RTOL iterations 3
>> Picard iteration 3 max(resid) = 137348 ------- Rate = 3.54418
>>  0 KSP Residual norm 7.285359985607e+05
>>  1 KSP Residual norm 9.132700545850e+04
>>  2 KSP Residual norm 6.834608381922e+03
>> Linear solve converged due to CONVERGED_RTOL iterations 2
>> Picard iteration 4 max(resid) = 25082.7 ------- Rate = 5.47582
>>  0 KSP Residual norm 1.207523847817e+05
>>  1 KSP Residual norm 1.286174706329e+04
>> Linear solve converged due to CONVERGED_RTOL iterations 1
>> Picard iteration 5 max(resid) = 5723.21 ------- Rate = 4.38264
>>  0 KSP Residual norm 2.211945822133e+04
>> Linear solve converged due to CONVERGED_RTOL iterations 0
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111214/01e28ee0/attachment.html>
