[petsc-dev] MatView on dense matrices crashes
Alexander Grayver agrayver at gfz-potsdam.de
Thu Dec 8 10:19:29 CST 2011
Hi dev-team,
Using this code from Fortran:
call PetscViewerBinaryOpen(sub%comm3d,'S.dat',FILE_MODE_WRITE,dviewer,ierr)
call PetscViewerSetFormat(dviewer,PETSC_VIEWER_NATIVE,ierr)
call MatView(S,dviewer,ierr)
crashes program with error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: To store a parallel dense matrix you must first call
PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE)!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
65c529a610ceec3880844014d1188a718bb5f1fa  HG Date: Wed Dec 07 04:10:48
2011 -0600
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: /home/emp on a openmpi-i named glic1 by agrayver Thu
Dec  8 17:06:27 2011
[0]PETSC ERROR: Libraries linked from
/home/lib/petsc-dev/openmpi-intel-complex-debug-f-ds/lib
[0]PETSC ERROR: Configure run at Wed Dec  7 17:18:42 2011
[0]PETSC ERROR: Configure options
--with-petsc-arch=openmpi-intel-complex-debug-f-ds
--with-fortran-interfaces=1 --download-superlu_dist --download-mumps
--download-parmetis --download-metis
--with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
--with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
--with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
--with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-precision=double --with-x=0
[0]PETSC ERROR:
[0]PETSC ERROR: MatView_MPIDense_Binary() line 678 in
/home/lib/petsc-dev/src/mat/impls/dense/mpi/mpidense.c
[0]PETSC ERROR: MatView_MPIDense() line 800 in
[0]PETSC ERROR: MatView() line 761 in
/home/lib/petsc-dev/src/mat/interface/matrix.c
Whereas same code works well with petsc-3.2-p5.
Same problem for release version has been reported and fixed here:
https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2011-September/010130.html
Alexander
