[petsc-dev] Error during compiling petsc-dev with Fortran
Wed Dec 7 04:11:34 CST 2011
On Wed, Dec 7, 2011 at 4:01 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> There are more:
Repeat steps from below. This looks like test code.
   Matt
> [  0%] Building Fortran object
> CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o
> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1058): error
> #5082: Syntax error, found END-OF-STATEMENT when expecting one of: ( % : .
>        MatTransposeColoring c ! MatTransposeColoring
> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1063): error
>        MatTransposeColoring coloring ! MatTransposeColoring
> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1070): error
>        MatTransposeColoring matcoloring ! MatTransposeColoring
> /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1079): error
>        MatTransposeColoring color ! MatTransposeColoring
> #6622: This statement is invalid in an INTERFACE block.
> #6218: This statement is positioned incorrectly and/or has syntax errors.
> compilation aborted for /home/lib/petsc-dev/src/mat/f90-mod/petscmatmod.F
> (code 1)
> make[5]: *** [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o] Error 1
> make[4]: ***
> [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o.provides] Error 2
> make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
> make[2]: *** [all] Error 2
> On 07.12.2011 10:39, Matthew Knepley wrote:
> On Wed, Dec 7, 2011 at 3:33 AM, Alexander Grayver <agrayver at gfz-potsdam.de
> > wrote:
>>  Hi Matt,
>> Unfortunately I don't have Mercurial installed on the cluster (will
>> negotiate it with admin soon), so I downloaded tarball.
>> Is there a simple patch for that?
>  1) Just install it to your home dir. Its very small
>  2) Go to include/finclude/ftn-auto/petscviewer.h90, remove lines 88--94
>    Matt
>>  Regards,
>> Alexander
>> On 07.12.2011 10:32, Matthew Knepley wrote:
>> On Wed, Dec 7, 2011 at 3:23 AM, Alexander Grayver <
>> agrayver at gfz-potsdam.de> wrote:
>>> Hi dev-team,
>>> Trying to compile petsc-dev with IFC 11.1 I got:
>>> CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
>>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/include/finclude/ftn-auto/petscviewer.h90(91):
>>> error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: (
>>>       PetscViewerVTKWriteFunction func ! PetscViewerVTKWriteFunction
>>> error #6622: This statement is invalid in an INTERFACE block.
>>> error #6218: This statement is positioned incorrectly and/or has syntax
>>> errors.
>>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/src/sys/f90-mod/petscsysmod.F
>>> (code 1)
>>> make[5]: *** [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o]
>>> Error 1
>>> make[4]: ***
>>> [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides] Error 2
>>> How it can be fixed?
>>  Pull, make allfortranstubs, and the build again.
>>     Matt
>>> Thanks in advance.
>>> Regards,
>>>  Alexander
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111207/7666099d/attachment.html>
