[petsc-dev] Error during compiling petsc-dev with Fortran
Wed Dec 7 03:39:04 CST 2011
On Wed, Dec 7, 2011 at 3:33 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> Hi Matt,
> Unfortunately I don't have Mercurial installed on the cluster (will
> negotiate it with admin soon), so I downloaded tarball.
> Is there a simple patch for that?
1) Just install it to your home dir. Its very small
2) Go to include/finclude/ftn-auto/petscviewer.h90, remove lines 88--94
  Matt
> Regards,
> Alexander
> On 07.12.2011 10:32, Matthew Knepley wrote:
> On Wed, Dec 7, 2011 at 3:23 AM, Alexander Grayver <agrayver at gfz-potsdam.de
> > wrote:
>> Hi dev-team,
>> Trying to compile petsc-dev with IFC 11.1 I got:
>> [  0%] Building Fortran object
>> CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/include/finclude/ftn-auto/petscviewer.h90(91):
>> error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: (
>>       PetscViewerVTKWriteFunction func ! PetscViewerVTKWriteFunction
>> error #6622: This statement is invalid in an INTERFACE block.
>> error #6218: This statement is positioned incorrectly and/or has syntax
>> errors.
>> compilation aborted for
>> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/src/sys/f90-mod/petscsysmod.F
>> (code 1)
>> make[5]: *** [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o] Error
>> 1
>> make[4]: ***
>> [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides] Error 2
>> make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
>> make[2]: *** [all] Error 2
>> How it can be fixed?
>  Pull, make allfortranstubs, and the build again.
>     Matt
>> Thanks in advance.
>> Regards,
>>  Alexander
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111207/59b57f2a/attachment.html>
