[petsc-dev] XDMF viewers
Sat Dec 3 14:45:54 CST 2011
On Sat, Dec 3, 2011 at 2:39 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Dec 3, 2011 at 14:31, Tim Gallagher <tim.gallagher at gatech.edu>wrote:
>> I was looking for the 'PETSc' way of doing it, something that lets you
>> call VecView(vec, viewer) that generates the heavy data and XML file
>> together. If there is not interest in that approach, I can just write the
>> routines to make the XML in the code.
> I don't know if Matt has that in PyLith, or if they use a less composable
> interface.
Yes, you can write several vectors using VecView(), AND you can do
timesteps :)
   Matt
> Binary-appended VTK does work this way. You can write several vectors to a
> file and they are held in memory until you close the file. The
> implementation is memory-scalable in the sense that there are no gathers of
> global state onto one process.
> Unfortunately, you cannot write many time steps to the same file, so you
> should usually create a separate file per step. (Lots of vis software likes
> this, so it's not a terrible restriction, although I don't like it.)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111203/08735b22/attachment.html>
