[petsc-dev] Seeking Advice on Petsc Preconditioners to Try
Mark F. Adams mark.adams at columbia.edu
Fri Dec 2 18:26:12 CST 2011
On Dec 2, 2011, at 6:06 PM, Dave Nystrom wrote:
> Mark F. Adams writes:
>> It sounds like you have a symmetric positive definite systems like du/dt -
>> div(alpha(x) grad)u.  The du/dt term makes the systems easier to solve.
>> I'm guessing your hard system does not have this mass term and so is
>> purely elliptic.  Multigrid is well suited for this type of problem, but
>> the vector nature requires some thought.  You could use PETSc AMG -pc_type
>> gamg but you need to tell it that you have a system of two dof/vertex.
>> You can do that with something like:
>> ierr = MatSetBlockSize( mat, 2 );      CHKERRQ(ierr);
>> For the best results from GAMG you need to give it null space information
>> but we can worry about that later.
> Hi Mark,
> I have been interested in trying some of the multigrid capabilities in
> petsc.  I'm not sure I remember seeing GAMG so I guess I should go look for
> that.
GAMG is pretty new.
> I have tried sacusp and sacusppoly but did not get good results on
> this particular linear system.
> In particular, sacusppoly seems broken.  I
> can't get it to work even with the petsc src/ksp/ksp/examples/tutorials/ex2.c
> example.  Thrust complains about an invalid device pointer I believe.
> Anyway, I can get the other preconditioners to work just fine on this petsc
> example problem.  When I try sacusp on this matrix for the case of generating
> a rhs from a known solution vector, the computed solution seems to diverge
> from the exact solution.  We also have an interface to an external agmg
> package which is not able to solve this problem
> but works well on the other 5
> linear solves.  So I'd like to try more from the multigrid toolbox but do not
> know much about how to supply the extra stuff that these packages often need.
> So, it sounds like you are suggesting that I try gamg and that I could at
> least try it out without having to initially supply lots of additional info.
> So I will take a look at gamg.
There are many things that can break a solver but most probably want to know that its a system so if you can set the block size and try gamg then that would be a good start.
> Thanks,
> Dave
>> Mark
>> On Nov 30, 2011, at 8:15 AM, Matthew Knepley wrote:
>>> On Wed, Nov 30, 2011 at 12:41 AM, Dave Nystrom <dnystrom1 at comcast.net> wrote:
>>> I have a linear system in a code that I have interfaced to petsc that is
>>> taking about 80 percent of the run time per timestep.  This linear system is
>>> a symmetric block banded matrix where the blocks are 2x2.  The matrix looks
>>> as follows:
>>> 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
>>> 1X X                     Y Y Y
>>> 2X X X                     Y Y Y
>>> 3  X X X                     Y Y Y
>>> 4    X X X                     Y Y Y
>>> 5      X X X                     Y Y Y
>>> 6        X X X                     Y Y Y
>>> 7          X X X                     Y Y Y
>>> 8            X X X                     Y Y Y
>>> 9              X X X                     Y Y Y
>>> 0                X X X                     Y Y Y
>>> 1                  X X X                     Y Y Y
>>> 2                    X X X                     Y Y Y
>>> 3Z                     X X X                     Y Y Y
>>> 4Z Z                     X X X                     Y Y Y
>>> 5Z Z Z                     X X X                     Y Y Y
>>> 6  Z Z Z                     X X X                     Y Y Y
>>> 7    Z Z Z                     X X X                     Y Y Y
>>> 8      Z Z Z                     X X X                     Y Y Y
>>> 9        Z Z Z                     X X X                     Y Y Y
>>> 0          Z Z Z                     X X X                     Y Y Y
>>> So in my diagram above, X, Y and Z are 2x2 blocks.  The symmetry of the
>>> matrix requires that X_ij = transpose(X_ji) and Y_ij = transpose(Z_ji).  So
>>> far, I have just input this matrix to petsc without indicating that it was
>>> block banded with 2x2 blocks.  I have also not told petsc that the matrix is
>>> symmetric.  And I have allowed petsc to decide the best way to store the
>>> matrix.
>>> I can solve this linear system over the course of a run using -ksp_type
>>> preonly -pc_type lu.  But that will not scale very well to larger problems
>>> that I want to solve.  I can also solve this system over the course of a run
>>> using -ksp_type cg -pc_type jacobi -vec_type cusp -mat_type aijcusp.
>>> However, over the course of a run, the iteration count ranges from 771 to
>>> 47300.  I have also tried sacusp, ainvcusp, sacusppoly, ilu(k) and icc(k)
>>> with k=0.  The sacusppoly preconditioner fails because of a thrust error
>>> related to an invalid device pointer, if I am remembering correctly.  I
>>> reported this problem to petsc-maint a while back and have also reported it
>>> for the cusp bugtracker.  But it does not appear that anyone has really
>>> looked into the bug.  For the other preconditioners of sacusp, ilu(k) and
>>> icc(k), they do not result in convergence to a solution and the runs fail.
>>> All preconditioners are custom. Have you done a literature search for PCs
>>> known to work for this problem? Can yu say anything about the spectrum of the
>>> operator? conditioning? what is the principal symbol (if its a PDE)? The pattern
>>> is not enough to recommend a PC.
>>>   Matt
>>> I'm wondering if there are suggestions of other preconditioners in petsc that
>>> I should try.  The only third party package that I have tried is the
>>> txpetscgpu package.  I have not tried hypre or any of the multigrid
>>> preconditioners yet.  I'm not sure how difficult it is to try those
>>> packages.  Anyway, so far I have not found a preconditioner available in
>>> petsc that provides a robust solution to this problem and would be interested
>>> in any suggestions that anyone might have of things to try.
>>> I'd be happy to provide additional info and am planning on packaging up a
>>> couple of examples of the matrix and rhs for people I am interacting with at
>>> Tech-X and EMPhotonics.  So I'd be happy to provide the matrix examples for
>>> this forum as well if anyone wants a copy.
>>> Thanks,
>>> Dave
>>> Dave Nystrom
>>> phone: 505-661-9943 (home office)
>>>      505-662-6893 (home)
>>> skype: dave.nystrom76
>>> email: dnystrom1 at comcast.net
>>> smail: 219 Loma del Escolar
>>>      Los Alamos, NM 87544
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
