[petsc-dev] Seeking Advice on Petsc Preconditioners to Try
Fri Dec 2 18:16:22 CST 2011
On Fri, Dec 2, 2011 at 5:46 PM, Dave Nystrom
<Dave.Nystrom at tachyonlogic.com>wrote:
> Matthew Knepley writes:
>  > On Wed, Nov 30, 2011 at 12:41 AM, Dave Nystrom <dnystrom1 at comcast.net
> >wrote:
>  > > I have a linear system in a code that I have interfaced to petsc that
> is
>  > > taking about 80 percent of the run time per timestep.  This linear
> system
>  > > is a symmetric block banded matrix where the blocks are 2x2.  The
> matrix
>  > > looks as follows:
>  > >  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
>  > > 1X X                     Y Y Y
>  > > 2X X X                     Y Y Y
>  > > 3  X X X                     Y Y Y
>  > > 4    X X X                     Y Y Y
>  > > 5      X X X                     Y Y Y
>  > > 6        X X X                     Y Y Y
>  > > 7          X X X                     Y Y Y
>  > > 8            X X X                     Y Y Y
>  > > 9              X X X                     Y Y Y
>  > > 0                X X X                     Y Y Y
>  > > 1                  X X X                     Y Y Y
>  > > 2                    X X X                     Y Y Y
>  > > 3Z                     X X X                     Y Y Y
>  > > 4Z Z                     X X X                     Y Y Y
>  > > 5Z Z Z                     X X X                     Y Y Y
>  > > 6  Z Z Z                     X X X                     Y Y Y
>  > > 7    Z Z Z                     X X X                     Y Y Y
>  > > 8      Z Z Z                     X X X                     Y Y Y
>  > > 9        Z Z Z                     X X X                     Y Y Y
>  > > 0          Z Z Z                     X X X                     Y Y Y
>  > > So in my diagram above, X, Y and Z are 2x2 blocks.  The symmetry of
> the
>  > > matrix requires that X_ij = transpose(X_ji) and Y_ij =
> transpose(Z_ji).  So
>  > > far, I have just input this matrix to petsc without indicating that
> it was
>  > > block banded with 2x2 blocks.  I have also not told petsc that the
> matrix
>  > > is symmetric.  And I have allowed petsc to decide the best way to
> store the
>  > > matrix.
>  > > I can solve this linear system over the course of a run using
> -ksp_type
>  > > preonly -pc_type lu.  But that will not scale very well to larger
> problems
>  > > that I want to solve.  I can also solve this system over the course
> of a
>  > > run using -ksp_type cg -pc_type jacobi -vec_type cusp -mat_type
> aijcusp.
>  > > However, over the course of a run, the iteration count ranges from
> 771 to
>  > > 47300.  I have also tried sacusp, ainvcusp, sacusppoly, ilu(k) and
> icc(k)
>  > > with k=0.  The sacusppoly preconditioner fails because of a thrust
> error
>  > > related to an invalid device pointer, if I am remembering correctly.
>  I
>  > > reported this problem to petsc-maint a while back and have also
> reported it
>  > > for the cusp bugtracker.  But it does not appear that anyone has
> really
>  > > looked into the bug.  For the other preconditioners of sacusp, ilu(k)
> and
>  > > icc(k), they do not result in convergence to a solution and the runs
> fail.
>  > All preconditioners are custom.  Have you done a literature search for
> PCs
>  > known to work for this problem?  Can you say anything about the
> spectrum of
>  > the operator? conditioning? what is the principal symbol (if its a PDE)?
>  > The pattern is not enough to recommend a PC.
> Hi Matt,
> Thanks for your reply and sorry to take so long to get back to you.  I have
> not done a literature search.  This is a time stepping code and so I have
> different linear systems for each linear solve and time step.  I have taken
> some time to study this particular system at a point in the nonlinear phase
> of the problem although there is definitely more I could do in that area.
>  At
> one point in the run, I have taken the matrix and generated a rhs using a
> known solution vector of random numbers between 0 and 1.  Using some petsc
> info that I believe Jed supplied to a previous question, I used petsc to
> print out the condition number estimate for the preconditioned system for
> various preconditioners.  The results seemed to be in the range of 10^5 to
> 10^7.  Also, when I computed error norms using a direct petsc LU solve, I
> was
> only getting 11-12 digits of accuracy.  On my other linear systems, I would
> get 15-16 digits of accuracy.  So the system is poorly conditioned.
>  However,
> the operator is computed from fields that are highly non-uniform over the
> spatial domain of the problem.  The problem is a formation problem for a
> Field Reversed Configuration (FRC) magnetic fusion problem.
No, this does not really help. For instance, from a Stokes problem we would
expect to hear, I am solving a Laplacian in the momentum equation, and
enforcing a differential constraint with the divergence. That allows us to
understand and build a preconditioner.
There is a simply staggeringly large literature on that problem. The time
has
come for a literature search.
It is very likely that sacusp was ineffective because you have a vector
problem,
but did not indicate this separation to the solver.
    Matt
> The matrix is symmetric but I am not sure if it is positive definite.  I
> can
> check symmetry easily with petsc but am not sure if there is an easy way to
> tell if the matrix is positive definite - if there is a good way to do this
> with petsc, I'd love to hear about it.  I did not find anything in the
> online
> help.  I wonder if petsc might be able to say something about the positive
> definiteness of the system after a solution has been found.  Anyway, I'm
> not
> up on the various ways to tell if a matrix is positive definite but I
> suppose
> it would be expensive to solve for all the eigenvalues of the matrix just
> to
> tell if it was positive definite.  If there are clever and inexpensive ways
> to do this, I'd be interested in trying them.
> However, I did try both minres and symmlq from petsc using jacobi
> preconditioning and cuda.  The case where I used minres ran to completion
> and
> used less than half the iterations that cg used so I was encouraged about
> that.  However, there was an issue with the final solution that I need to
> investigate.  The run using symmlq from petsc with jacobi preconditioning
> and
> cuda had numerical problems that I have not investigated and did not run to
> completion.
> So, because of the physics involved, the linear system is difficult to
> solve.  It seems poorly conditioned.  It is symmetric but might not be
> positive definite.  The matrix comes from discretizing a pde on a regular
> structured 2d mesh.
> Does any of this additional info help?
> Thanks,
> Dave
>  > Matt
>  > > I'm wondering if there are suggestions of other preconditioners in
> petsc
>  > > that I should try.  The only third party package that I have tried is
> the
>  > > txpetscgpu package.  I have not tried hypre or any of the multigrid
>  > > preconditioners yet.  I'm not sure how difficult it is to try those
>  > > packages.  Anyway, so far I have not found a preconditioner available
> in
>  > > petsc that provides a robust solution to this problem and would be
>  > > interested in any suggestions that anyone might have of things to try.
>  > > I'd be happy to provide additional info and am planning on packaging
> up a
>  > > couple of examples of the matrix and rhs for people I am interacting
> with
>  > > at Tech-X and EMPhotonics.  So I'd be happy to provide the matrix
>  > > examples for this forum as well if anyone wants a copy.
>  > > Thanks,
>  > > Dave
>  > > Dave Nystrom
>  > > phone: 505-661-9943 (home office)
>  > >       505-662-6893 (home)
>  > > skype: dave.nystrom76
>  > > email: dnystrom1 at comcast.net
>  > > smail: 219 Loma del Escolar
>  > >       Los Alamos, NM 87544
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111202/279042ae/attachment.html>
