[petsc-dev] hg problem
Mark F. Adams mark.adams at columbia.edu
Wed Aug 24 19:58:47 CDT 2011
I tried revert on this file (which I did not touch) iga.c but got a message to try 'hg revert help' ... which was no help.
So I just went ahead and committed the whole thing and and that cleared it up.  I've appended the diffs, but as I said I've never touched this file.  Hope I didn't clobber someones stuff,
diff -r 4bf480f9a778 src/dm/impls/iga/iga.c
--- a/src/dm/impls/iga/iga.c    Wed Aug 24 17:08:17 2011 -0700
+++ b/src/dm/impls/iga/iga.c    Wed Aug 24 17:43:52 2011 -0700
@@ -1555,24 +1555,22 @@
 #define __FUNCT__ "CreateKnotVector"
 PetscErrorCode CreateKnotVector(PetscInt N,PetscInt p,PetscInt C,PetscInt m, PetscReal *U,PetscReal U0,PetscReal Uf)
-  PetscInt i,j;
+  PetscInt  i,j;
   PetscReal dU;
-  PetscInt  k0;
   PetscFunctionBegin;
-  for(i=0;i<p+1;i++) /* open part */
+  dU = (Uf-U0)/N;
+  for(i=0;i<(N-1);i++) /* insert N-1 knots */
+    for(j=0;j<(p-C);j++) /* p-C times */
+      U[(p+1) + i*(p-C) + j] = U0 + (i+1)*dU;
+  for(i=0;i<(p+1);i++) /* open part */
     U[i] = U0;
     U[m-i-1] = Uf;
-  dU = (Uf-U0)/((PetscReal) N);
-  k0 = p+1;
-  for(i=0;i<(N-1);i++) /* insert N-1 knots */
-    for(j=0;j<(p-C);j++) /* p-C+1 times */
-      U[k0 + i*(p-C) + j] = U0+((PetscReal) (i+1))*dU;
   PetscFunctionReturn(0);
@@ -1580,29 +1578,22 @@
 #define __FUNCT__ "CreatePeriodicKnotVector"
 PetscErrorCode CreatePeriodicKnotVector(PetscInt N,PetscInt p,PetscInt C,PetscInt m, PetscReal *U,PetscReal U0,PetscReal Uf)
-  PetscInt i,j;
+  PetscInt  i,j;
   PetscReal dU;
-  PetscInt  k0;
-  PetscFunctionBegin; /* periodic part */
-  U[p] = U0;
-  U[m-p-1] = Uf;
+  PetscFunctionBegin;
-  k0 = p+1;
+  dU = (Uf-U0)/N;
+  for(i=0;i<(N+1);i++) /* insert N+1 knots */
+      U[(C+1) + i*(p-C) + j] = U0 + i*dU;
+  for(i=0;i<(C+1);i++) /* periodic part */
+    U[i] = U0 - (Uf - U[(m-1-p)-(C+1)+i]);
+    U[m-(C+1)+i] = Uf + (U[p+1+i] - U0);
-  for(i=0;i<p;i++)
-      U[i] = -U[m-p-1]+U[m-p-1-(p-i)];
-      U[m-p+i] = U[m-p-1]+U[p+i+1];
On Aug 24, 2011, at 8:45 PM, Jed Brown wrote:
> On Wed, Aug 24, 2011 at 19:16, Mark F. Adams <mark.adams at columbia.edu> wrote:
> I'm stuck.  I seem to have some file that I know nothing about:
> examples/tutorials> hg status -m
> M src/dm/impls/iga/iga.c
> that seems to be holding me up from doing just about anything with hg.  I've tried reverting it with not luck.
> hg diff   -- to see if there is anything you want to keep
> hg revert src/dm/impls/iga/iga.c   -- to discard those changes
> hg update -C   -- to discard any changes in the current working tree and update to the given revision (tip, by default)
> If you have a problem with these, paste the full output.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110824/74fa81ae/attachment.html>
