[petsc-dev] ts/examples/tutorials/ex11 test garbage?
Wed Aug 17 08:35:04 CDT 2011
On Wed, Aug 17, 2011 at 07:14, Richard Katz <richard.katz at earth.ox.ac.uk>wrote:
> For my uses this is a very important feature.
> Two questions:
> - Will the step size increase after a shorter step has been successful?
>  Will it go immediately back to the maximum size?
The details depend on the adaptive controller. Unfortunately, we haven't yet
unified the interface for adaptive controllers, so, for example, TSALPHA and
TSGL have different APIs. But both of them provide adaptive controllers now
and the rate of increase can be limited.
I think having these interfaces is really undesirable and that we should
unify it, but the information provided by the error estimates for TSGL are
quite different from most methods (OTOH, they seem to me noisy which limits
their utility, but there are other possible reasons for that, including
"starting methods").
> - Will it be possible to set a minimum step size, below which the TSSolve()
> or TSStep() will "crap out?"
> It is obviously important that TS not just chug along without error if a
> timestep fails.
So this is possible, but it's somewhat inconsistent between methods. It
would help a great deal to build a suite of test problems that provide some
way to evaluate error (even just through self-convergence) so that we can
test whether an adaptive method is performing well.
My intent is to provide some common interface for adaptive controllers as
well as some sample controllers. The controller can evaluate whether to
accept or reject a step as well as choosing the next time step and, for the
variable-order families, the method to use for the next step (selected from
a list of candidate schemes). This is basically what I did in TSGL and
later, and what Lisandro did in TSAlpha, but we need to unify the interface
despite these methods giving us somewhat different information in their
(embedded or extrapolated) error estimates.
I think TSAlpha has the best tested adaptive controller right now. Getting
all the cool adaptive features into TSARKIMEX is next, hopefully with a
unified interface for user-provided controllers.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110817/c88d0bba/attachment.html>
