[petsc-dev] failing test
Lisandro Dalcin dalcinl at gmail.com
Fri Apr 29 09:34:58 CDT 2011
On 29 April 2011 00:36, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Lisandro :
> Has this been fixed? I cannot reproduce it on petsc machine or my Mac.
> Hong
Still failing here (shared lib build, using mpich2 1.2.1p1 from Fedora 13)
>> Can any one take a look here? It is unlikely that is is caused by my
>> commit "dbddbea75f68". It smells as an issue with Viewers created on
>> subcommunicators.
>> [dalcinl at trantor tutorials]$ cd $PETSC_DIR/src/ksp/ksp/examples/tutorials
>> [dalcinl at trantor tutorials]$ make runex2_bjacobi_2
>> 42a43,56
>>> [0]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
>>> [0]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
>>> [0]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
>>> [0]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>> [0]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>> [0]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
>>> [1]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
>>> [1]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
>>> [1]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
>>> [1]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>> [1]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>> [1]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
>>> rank 0 in job 7851  trantor_56062   caused collective abort of all ranks
>>>   exit status of rank 0: return code 0
>> Possible problem with ex2_bjacobi_2, diffs above
>> Lisandro Dalcin
>> CIMEC (INTEC/CONICET-UNL)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> 3000 Santa Fe, Argentina
>> Tel: +54-342-4511594 (ext 1011)
>> Tel/Fax: +54-342-4511169
Lisandro Dalcin
