[petsc-dev] change to MatIsTranspose() and failing test
Hong Zhang hzhang at mcs.anl.gov
Wed Apr 27 15:06:58 CDT 2011
I'll check it. Hong
On Wed, Apr 27, 2011 at 2:04 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> After wasting as considerable amount of time debugging issues related
> to uninitialized variables passed to MatIsTranspose, I've pushed this:
> changeset:   18869:3bdc748ba073
> tag:         tip
> user:        Lisandro Dalcin <dalcinl at gmail.com>
> date:        Wed Apr 27 15:59:56 2011 -0300
> summary:     MatIsTranspose(): error if any matrix does not support the test
> And now, the best below fails, becase SeqBAIJ does not support transpose test.
> [dalcinl at trantor tests]$ cd $PETSC_DIR/src/ksp/ksp/examples/tests
> [dalcinl at trantor tests]$ make runex32_aij_sbaij_icc
> make: [runex32_aij_sbaij_icc] Error 56 (ignored)
> 1,19c1,7
> < [0]PETSC ERROR: --------------------- Error Message
> < [0]PETSC ERROR: No support for this operation for this object type!
> < [0]PETSC ERROR: Matrix of type <seqbaij> does not support checking
> for transpose!
> < [0]PETSC ERROR:
> < [0]PETSC ERROR: Petsc Development HG revision:
> a02bb9bcaf33cf16868e2771c3c8306d52235c69  HG Date: Fri Apr 22 13:15:40
> 2011 -0500
> < [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> < [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> < [0]PETSC ERROR: See docs/index.html for manual pages.
> < [0]PETSC ERROR:
> < [0]PETSC ERROR: ./ex32 on a arch-linu named trantor by dalcinl Wed
> Apr 27 16:00:08 2011
> < [0]PETSC ERROR: Libraries linked from
> /home/devel/petsc/dev/arch-linux2-c-debug/lib
> < [0]PETSC ERROR: Configure run at Sat Apr 23 17:40:22 2011
> < [0]PETSC ERROR: Configure options --with-shared-libraries=1
> PETSC_ARCH=arch-linux2-c-debug
> < [0]PETSC ERROR:
> < [0]PETSC ERROR: MatIsTranspose() line 4383 in
> /home/devel/petsc/dev/src/mat/interface/matrix.c
> < [0]PETSC ERROR: main() line 69 in src/ksp/ksp/examples/tests/ex32.c
> < application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> < rank 0 in job 3534  trantor_56062   caused collective abort of all ranks
> <   exit status of rank 0: return code 56
>>   0 KSP Residual norm 0.210648
>>   1 KSP Residual norm 0.07826
>>   2 KSP Residual norm 0.0115565
>>   3 KSP Residual norm 0.00113989
>>   4 KSP Residual norm 0.00013248
>>   5 KSP Residual norm 9.04476e-06
>>   6 KSP Residual norm 4.52149e-07
> Possible problem with ex32_aij_sbaij_icc, diffs above
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
