[petsc-dev] KSP run in parallel with GPU
Eugene Kozlov neoveneficus at gmail.com
Mon Apr 25 09:30:21 CDT 2011
I never use the maillist before this. How can I better show logs?
Attach file to mail?
Norm of error 0.00012322 iterations 448
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
-fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance
Summary: ----------------------------------------------
ex2 on a arch-linu named cn11 with 1 processor, by kukushkinav Mon Apr
25 18:24:15 2011
Using Petsc Development HG revision:
d3e10315d68b1dd5481adb2889c7d354880da362  HG Date: Wed Apr 20 21:03:56
2011 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           3.891e+01      1.00000   3.891e+01
Objects:              2.500e+01      1.00000   2.500e+01
Flops:                9.474e+09      1.00000   9.474e+09  9.474e+09
Flops/sec:            2.435e+08      1.00000   2.435e+08  2.435e+08
Memory:               1.562e+08      1.00000              1.562e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       5.881e+03      1.00000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length
N --> 2N flops
                            and VecAXPY() for complex vectors of
length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  ---
Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts
%Total     Avg         %Total   counts   %Total
 0:      Main Stage: 3.8368e+01  98.6%  9.4739e+09 100.0%  0.000e+00
0.0%  0.000e+00        0.0%  5.855e+03  99.6%
 1:        Assembly: 5.3823e-01   1.4%  0.0000e+00   0.0%  0.000e+00
0.0%  0.000e+00        0.0%  1.200e+01   0.2%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush()
and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message
lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops
          --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
MatMult              449 1.0 1.4191e+00 1.0 2.87e+09 1.0 0.0e+00
0.0e+00 0.0e+00  4 30  0  0  0   4 30  0  0  0  2023
MatSolve             449 1.0 1.3127e+01 1.0 2.58e+09 1.0 0.0e+00
0.0e+00 0.0e+00 34 27  0  0  0  34 27  0  0  0   197
MatCholFctrNum         1 1.0 1.7007e-01 1.0 6.40e+05 1.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     4
MatICCFactorSym        1 1.0 1.1560e-01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            1 1.0 1.1921e-06 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 1.0 1.0204e-01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCUSPCopyTo          2 1.0 2.0546e-02 1.0 0.00e+00 0.0 0.0e+00
VecDot               896 1.0 1.0086e+00 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 1.8e+03  3 12  0  0 30   3 12  0  0 31  1137
VecNorm              450 1.0 8.4599e-01 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 9.0e+02  2 12  0  0 15   2 12  0  0 15  1362
VecCopy                2 1.0 2.6081e-03 1.0 0.00e+00 0.0 0.0e+00
VecSet               451 1.0 2.7629e-01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              897 1.0 2.1131e-01 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 0.0e+00  1 12  0  0  0   1 12  0  0  0  5434
VecAYPX              447 1.0 1.0049e-01 1.0 5.72e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0  5694
VecScatterBegin      449 1.0 6.8694e-01 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
VecCUSPCopyTo       1346 1.0 1.2865e+00 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
VecCUSPCopyFrom     1346 1.0 2.2437e+00 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0
KSPSetup               2 1.0 3.1233e-05 1.0 0.00e+00 0.0 0.0e+00
KSPSolve               1 1.0 1.8947e+01 1.0 9.46e+09 1.0 0.0e+00
0.0e+00 5.8e+03 49100  0  0 99  49100  0  0100   499
PCSetUp                2 1.0 3.8846e-01 1.0 6.40e+05 1.0 0.0e+00
0.0e+00 7.0e+00  1  0  0  0  0   1  0  0  0  0     2
PCSetUpOnBlocks        1 1.0 3.8828e-01 1.0 6.40e+05 1.0 0.0e+00
0.0e+00 5.0e+00  1  0  0  0  0   1  0  0  0  0     2
PCApply              449 1.0 1.4987e+01 1.0 2.58e+09 1.0 0.0e+00
0.0e+00 1.8e+03 39 27  0  0 31  39 27  0  0 31   172
--- Event Stage 1: Assembly
MatAssemblyBegin       1 1.0 2.3842e-05 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0 17     0
MatAssemblyEnd         1 1.0 7.0319e-02 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 1.0e+01  0  0  0  0  0  13  0  0  0 83     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Matrix     4              4    120310620     0
                 Vec     8              9     20493272     0
         Vec Scatter     0              1          596     0
           Index Set     3              3      2562160     0
       Krylov Solver     2              2         2048     0
      Preconditioner     2              2         1688     0
              Viewer     1              0            0     0
                 Vec     2              1         1496     0
         Vec Scatter     1              0            0     0
           Index Set     2              2         1432     0
Average time to get PetscTime(): 9.53674e-08
#PETSc Option Table entries:
-ksp_type cg
-log_summary
-m 800
-mat_type mpiaijcusp
-n 800
-vec_type mpicusp
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8
Configure run at: Mon Apr 25 12:42:34 2011
Configure options: --prefix=/home/kukushkinav
--with-blas-lapack-dir=/opt/intel/composerxe-2011.0.084/mkl
--with-mpi-dir=/opt/intel/impi/4.0.1.007/intel64/bin --with-cuda=1
--with-cusp=1 --with-thrust=1
--with-thrust-dir=/home/kukushkinav/include
--with-cusp-dir=/home/kukushkinav/include --with-cuda-arch=sm_13
Libraries compiled on Mon Apr 25 12:42:34 2011 on manager
Machine characteristics: Linux-2.6.18-238.5.1.el5-x86_64-with-redhat-5.6-Tikanga
Using PETSc directory: /export/home/kukushkinav/soft/petsc-dev
Using PETSc arch: arch-linux2-c-debug
Using C compiler: mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g3  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: mpif90  -Wall -Wno-unused-variable -g
${FOPTFLAGS} ${FFLAGS}
Using include paths:
-I/export/home/kukushkinav/soft/petsc-dev/arch-linux2-c-debug/include
-I/export/home/kukushkinav/soft/petsc-dev/include
-I/usr/local/cuda/include -I/home/kukushkinav/include/
-I/opt/intel/impi/4.0.1.007/intel64/bin/include
-I/opt/intel/impi/4.0.1.007/intel64/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries:
-Wl,-rpath,/export/home/kukushkinav/soft/petsc-dev/arch-linux2-c-debug/lib
-L/export/home/kukushkinav/soft/petsc-dev/arch-linux2-c-debug/lib
-lpetscts -lpetscsnes -lpetscksp -lpetscdm -lpetscmat -lpetscvec
-lpetscsys -lX11 -Wl,-rpath,/usr/local/cuda/lib64
-L/usr/local/cuda/lib64 -lcufft -lcublas -lcudart
-Wl,-rpath,/opt/intel/composerxe-2011.0.084/mkl
-L/opt/intel/composerxe-2011.0.084/mkl -lmkl_intel_lp64
-lmkl_intel_thread -lmkl_core -liomp5 -lpthread -ldl
-L/opt/intel/impi/4.0.1.007/intel64/lib
-L/opt/intel/composerxe-2011.0.084/compiler/lib/intel64
-L/opt/intel/composerxe-2011.0.084/mkl/lib/intel64
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -lmpi -lmpigf -lmpigi
-lpthread -lrt -lgcc_s
-Wl,-rpath,/export/home/kukushkinav/soft/petsc-dev/-Xlinker -lmpi_dbg
-lgfortran -lm -Wl,-rpath,/opt/intel/impi/4.0.1.007/intel64/lib
-Wl,-rpath,/opt/intel/mpi-rt/4.0.1 -lm -lmpigc4 -lmpi_dbg -lstdc++
-lmpigc4 -lmpi_dbg -lstdc++ -ldl -lmpi -lmpigf -lmpigi -lpthread -lrt
-lgcc_s -ldl
25 18:24:15 2011
2011 -0500
Time (sec):           3.892e+01      1.00000   3.892e+01
Flops/sec:            2.434e+08      1.00000   2.434e+08  2.434e+08
N --> 2N flops
 1:        Assembly: 5.4742e-01   1.4%  0.0000e+00   0.0%  0.000e+00
Phase summary info:
      #                          WARNING!!!                    #
MatMult              449 1.0 1.4400e+00 1.0 2.87e+09 1.0 0.0e+00
0.0e+00 0.0e+00  4 30  0  0  0   4 30  0  0  0  1994
MatSolve             449 1.0 1.3012e+01 1.0 2.58e+09 1.0 0.0e+00
0.0e+00 0.0e+00 33 27  0  0  0  34 27  0  0  0   199
MatCholFctrNum         1 1.0 1.7184e-01 1.0 6.40e+05 1.0 0.0e+00
MatICCFactorSym        1 1.0 1.1631e-01 1.0 0.00e+00 0.0 0.0e+00
MatGetRowIJ            1 1.0 1.9073e-06 1.0 0.00e+00 0.0 0.0e+00
MatGetOrdering         1 1.0 1.0190e-01 1.0 0.00e+00 0.0 0.0e+00
MatCUSPCopyTo          2 1.0 2.1061e-02 1.0 0.00e+00 0.0 0.0e+00
VecDot               896 1.0 1.0891e+00 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 1.8e+03  3 12  0  0 30   3 12  0  0 31  1053
VecNorm              450 1.0 1.1033e+00 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 9.0e+02  3 12  0  0 15   3 12  0  0 15  1044
VecCopy                2 1.0 2.7471e-03 1.0 0.00e+00 0.0 0.0e+00
VecSet               451 1.0 2.5600e-01 1.0 0.00e+00 0.0 0.0e+00
VecAXPY              897 1.0 1.9726e-01 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 0.0e+00  1 12  0  0  0   1 12  0  0  0  5821
VecAYPX              447 1.0 1.0141e-01 1.0 5.72e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0  5642
VecScatterBegin      449 1.0 6.9110e-01 1.0 0.00e+00 0.0 0.0e+00
VecCUSPCopyTo       1346 1.0 1.5747e+00 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
VecCUSPCopyFrom     1346 1.0 2.0444e+00 1.0 0.00e+00 0.0 0.0e+00
0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0     0
KSPSetup               2 1.0 4.0770e-05 1.0 0.00e+00 0.0 0.0e+00
KSPSolve               1 1.0 1.8957e+01 1.0 9.46e+09 1.0 0.0e+00
PCSetUp                2 1.0 3.9091e-01 1.0 6.40e+05 1.0 0.0e+00
PCSetUpOnBlocks        1 1.0 3.9070e-01 1.0 6.40e+05 1.0 0.0e+00
PCApply              449 1.0 1.4649e+01 1.0 2.58e+09 1.0 0.0e+00
0.0e+00 1.8e+03 38 27  0  0 31  38 27  0  0 31   176
MatAssemblyBegin       1 1.0 3.9101e-05 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyEnd         1 1.0 7.0405e-02 1.0 0.00e+00 0.0 0.0e+00
                 Vec     8              9     20493272     0
              Viewer     1              0            0     0
                 Vec     2              1         1496     0
         Vec Scatter     1              0            0     0
-ksp_type cg
-log_summary
-m 800
-n 800
-vec_type mpicusp
Using libraries:
-lgcc_s -ldl
25 18:24:16 2011
2011 -0500
Time (sec):           3.946e+01      1.00000   3.946e+01
Flops/sec:            2.401e+08      1.00000   2.401e+08  2.401e+08
N --> 2N flops
 0:      Main Stage: 3.8927e+01  98.6%  9.4739e+09 100.0%  0.000e+00
 1:        Assembly: 5.3425e-01   1.4%  0.0000e+00   0.0%  0.000e+00
Phase summary info:
      #                          WARNING!!!                    #
MatMult              449 1.0 1.4559e+00 1.0 2.87e+09 1.0 0.0e+00
0.0e+00 0.0e+00  4 30  0  0  0   4 30  0  0  0  1972
MatSolve             449 1.0 1.2787e+01 1.0 2.58e+09 1.0 0.0e+00
0.0e+00 0.0e+00 32 27  0  0  0  33 27  0  0  0   202
MatCholFctrNum         1 1.0 1.6867e-01 1.0 6.40e+05 1.0 0.0e+00
MatICCFactorSym        1 1.0 1.1588e-01 1.0 0.00e+00 0.0 0.0e+00
MatGetOrdering         1 1.0 1.0179e-01 1.0 0.00e+00 0.0 0.0e+00
MatCUSPCopyTo          2 1.0 1.9272e-02 1.0 0.00e+00 0.0 0.0e+00
VecDot               896 1.0 1.1960e+00 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 1.8e+03  3 12  0  0 30   3 12  0  0 31   959
VecNorm              450 1.0 1.0563e+00 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 9.0e+02  3 12  0  0 15   3 12  0  0 15  1091
VecCopy                2 1.0 2.4669e-03 1.0 0.00e+00 0.0 0.0e+00
VecSet               451 1.0 2.5303e-01 1.0 0.00e+00 0.0 0.0e+00
VecAXPY              897 1.0 1.9844e-01 1.0 1.15e+09 1.0 0.0e+00
0.0e+00 0.0e+00  1 12  0  0  0   1 12  0  0  0  5786
VecAYPX              447 1.0 1.0348e-01 1.0 5.72e+08 1.0 0.0e+00
0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0  5529
VecScatterBegin      449 1.0 7.1386e-01 1.0 0.00e+00 0.0 0.0e+00
VecCUSPCopyTo       1346 1.0 1.6784e+00 1.0 0.00e+00 0.0 0.0e+00
VecCUSPCopyFrom     1346 1.0 2.2173e+00 1.0 0.00e+00 0.0 0.0e+00
KSPSetup               2 1.0 4.5061e-05 1.0 0.00e+00 0.0 0.0e+00
KSPSolve               1 1.0 1.8962e+01 1.0 9.46e+09 1.0 0.0e+00
0.0e+00 5.8e+03 48100  0  0 99  49100  0  0100   499
PCSetUp                2 1.0 3.8716e-01 1.0 6.40e+05 1.0 0.0e+00
PCSetUpOnBlocks        1 1.0 3.8694e-01 1.0 6.40e+05 1.0 0.0e+00
PCApply              449 1.0 1.4576e+01 1.0 2.58e+09 1.0 0.0e+00
0.0e+00 1.8e+03 37 27  0  0 31  37 27  0  0 31   177
MatAssemblyBegin       1 1.0 5.1022e-05 1.0 0.00e+00 0.0 0.0e+00
MatAssemblyEnd         1 1.0 6.9999e-02 1.0 0.00e+00 0.0 0.0e+00
                 Vec     8              9     20493272     0
              Viewer     1              0            0     0
                 Vec     2              1         1496     0
         Vec Scatter     1              0            0     0
Average time to get PetscTime(): 0
-ksp_type cg
-log_summary
-m 800
-n 800
-vec_type mpicusp
Using libraries:
-lgcc_s -ldl
2011/4/25 Matthew Knepley <knepley at gmail.com>:
> On Mon, Apr 25, 2011 at 9:06 AM, Eugene Kozlov <neoveneficus at gmail.com>
> wrote:
>> Hello,
> To answer any kind of question about performance, we need the full output of
> -log_summary.
>     Matt
>> I am trying to test PETSc capability of solving sparse linear systems
>> in parallel with GPU.
>> I compiled and tried to run example
>> src/ksp/ksp/examples/tutorials/ex2.c, which can be executed in
>> parallel.
>> In this example matrix and vectors created using VecSetFromOptions()
>> and MatSetFromOptions().
>> According to the page
>> http://www.mcs.anl.gov/petsc/petsc-2/features/gpus.html , I execute
>> the program with keys
>> -vec_type mpicusp -mat_type mpiaijcusp
>> in parallel on the different number of GPUs. Full command:
>> cleo-submit -np 1 ex2 -ksp_type cg -vec_type mpicusp -mat_type
>> mpiaijcusp -m 800 -n 800
>> Where 'cleo-submit' is a batch manager utility.
>> I tested the program on 1, 2 and 3 GPUs. As a result I have output as
>> (for 3 GPUs):
>> and run times: 30, 40 and 46 seconds respectively.
>> What can be a cause of these results?
>> Best regards,
>> Eugene
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
