[petsc-dev] DACreate3d should work for 1 node in Z
Ethan Coon ecoon at lanl.gov
Tue Apr 19 17:35:25 CDT 2011
Ok, here's a patch that does the very very special case of:
p=P=1, s > p, DMDA_BOUNDARY_PERIODIC in the z-direction.
Note this is really only possible in the z-direction... when in the
z-direction, we can just check if the global index < 0 or > x*y*z and
adjust appropriately.  So this can't generalize to x- or y- directions
(though it could do the y-direction in the 2D case, allowing one to do
1D problems in a 2D algorithm?)
Compared to the rest of the cruft in da3.c and how non-general the
global index generation is overall, it's not actually that ugly...
I've tested with s=2 and 3, BOX and STAR, and the indices look right
(i.e. they are identical in the z-dimension).  But it's ugly, so please
test with your stuff too Jed.
Ethan
On Tue, 2011-04-19 at 23:28 +0200, Jed Brown wrote:
> On Tue, Apr 19, 2011 at 23:21, Ethan Coon <ecoon at lanl.gov> wrote:
>         The attached patch fixes the errors to error in the correct
>         cases.
> Pushed, thanks.
Ethan Coon
Post-Doctoral Researcher
Applied Mathematics - T-5
Los Alamos National Laboratory
505-665-8289
http://www.ldeo.columbia.edu/~ecoon/
cruft to handle the special case of solving a 2D problem in a 3D algorithm with stencil size > 1.  This only works in the 3D case, z-dimension
diff -r 3ad7a426c22b src/dm/impls/da/da3.c
--- a/src/dm/impls/da/da3.c	Tue Apr 19 15:18:30 2011 -0600
+++ b/src/dm/impls/da/da3.c	Tue Apr 19 16:25:22 2011 -0600
@@ -331,7 +331,10 @@
   z  = lz[rank/(m*n)];
-  if ((z < s) && ((p > 1) || bz == DMDA_BOUNDARY_PERIODIC)) {
+  /* note this is different than x- and y-, as we will handle as an important special
+   case when p=P=1 and DMDA_BOUNDARY_PERIODIC and s > z.  This is to deal with 2D problems
+   in a 3D code.  Additional code for this case is noted with "2d case" comments */
+  if ((z < s) && ((p > 1) || ((P > 1) && bz == DMDA_BOUNDARY_PERIODIC))) {
     SETERRQ2(PETSC_COMM_SELF,PETSC_ERR_ARG_OUTOFRANGE,"Local z-width of domain z %D is smaller than stencil width s %D",z,s);
   zs = 0;
@@ -739,6 +742,7 @@
         y_t = ly[(n0 % (m*n))/m];
         z_t = lz[n0 / (m*n)];
         s_t = bases[n0] + x_t*y_t*z_t - (s_y-i)*x_t - s_x - (s_z-k-1)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n0] + x_t*y_t*z_t - (s_y-i)*x_t - s_x;} /* 2D case */
         for (j=0; j<s_x; j++) { idx[nn++] = s_t++;}
       if (n1 >= 0) { /* directly below */
@@ -746,6 +750,7 @@
         y_t = ly[(n1 % (m*n))/m];
         z_t = lz[n1 / (m*n)];
         s_t = bases[n1] + x_t*y_t*z_t - (s_y+1-i)*x_t - (s_z-k-1)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n1] + x_t*y_t*z_t - (s_y+1-i)*x_t;} /* 2D case */
         for (j=0; j<x_t; j++) { idx[nn++] = s_t++;}
       if (n2 >= 0) { /* right below */
@@ -753,6 +758,7 @@
         y_t = ly[(n2 % (m*n))/m];
         z_t = lz[n2 / (m*n)];
         s_t = bases[n2] + x_t*y_t*z_t - (s_y+1-i)*x_t - (s_z-k-1)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n2] + x_t*y_t*z_t - (s_y+1-i)*x_t;} /* 2D case */
@@ -763,6 +769,7 @@
         y_t = y;
         z_t = lz[n3 / (m*n)];
         s_t = bases[n3] + (i+1)*x_t - s_x + x_t*y_t*z_t - (s_z-k)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n3] + (i+1)*x_t - s_x + x_t*y_t*z_t - x_t*y_t;} /* 2D case */
@@ -771,6 +778,7 @@
         y_t = y;
         z_t = lz[n4 / (m*n)];
         s_t = bases[n4] + i*x_t + x_t*y_t*z_t - (s_z-k)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n4] + i*x_t + x_t*y_t*z_t - x_t*y_t;} /* 2D case */
@@ -779,6 +787,7 @@
         y_t = y;
         z_t = lz[n5 / (m*n)];
         s_t = bases[n5] + i*x_t + x_t*y_t*z_t - (s_z-k)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n5] + i*x_t + x_t*y_t*z_t - x_t*y_t;} /* 2D case */
@@ -789,6 +798,7 @@
         y_t = ly[(n6 % (m*n))/m];
         z_t = lz[n6 / (m*n)];
         s_t = bases[n6] + i*x_t - s_x + x_t*y_t*z_t - (s_z-k)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n6] + i*x_t - s_x + x_t*y_t*z_t - x_t*y_t;} /* 2D case */
       if (n7 >= 0) { /* directly above */
@@ -796,6 +806,7 @@
         y_t = ly[(n7 % (m*n))/m];
         z_t = lz[n7 / (m*n)];
         s_t = bases[n7] + (i-1)*x_t + x_t*y_t*z_t - (s_z-k)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n7] + (i-1)*x_t + x_t*y_t*z_t - x_t*y_t;} /* 2D case */
       if (n8 >= 0) { /* right above */
@@ -803,6 +814,7 @@
         y_t = ly[(n8 % (m*n))/m];
         z_t = lz[n8 / (m*n)];
         s_t = bases[n8] + (i-1)*x_t + x_t*y_t*z_t - (s_z-k)*x_t*y_t;
+        if (s_t < 0) {s_t = bases[n8] + (i-1)*x_t + x_t*y_t*z_t - x_t*y_t;} /* 2D case */
@@ -889,6 +901,7 @@
         y_t = ly[(n18 % (m*n))/m];
         /* z_t = lz[n18 / (m*n)]; */
         s_t = bases[n18] - (s_y-i)*x_t -s_x + (k+1)*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n18] - (s_y-i)*x_t -s_x + x_t*y_t;} /* 2d case */
       if (n19 >= 0) { /* directly below */
@@ -896,6 +909,7 @@
         y_t = ly[(n19 % (m*n))/m];
         /* z_t = lz[n19 / (m*n)]; */
         s_t = bases[n19] - (s_y+1-i)*x_t + (k+1)*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n19] - (s_y+1-i)*x_t + x_t*y_t;} /* 2d case */
       if (n20 >= 0) { /* right below */
@@ -903,6 +917,7 @@
         y_t = ly[(n20 % (m*n))/m];
         /* z_t = lz[n20 / (m*n)]; */
         s_t = bases[n20] - (s_y+1-i)*x_t + (k+1)*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n20] - (s_y+1-i)*x_t + x_t*y_t;} /* 2d case */
@@ -913,6 +928,7 @@
         y_t = y;
         /* z_t = lz[n21 / (m*n)]; */
         s_t = bases[n21] + (i+1)*x_t - s_x + k*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n21] + (i+1)*x_t - s_x;}  /* 2d case */
@@ -921,6 +937,7 @@
         y_t = y;
         /* z_t = lz[n22 / (m*n)]; */
         s_t = bases[n22] + i*x_t + k*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n22] + i*x_t;} /* 2d case */
@@ -929,6 +946,7 @@
         y_t = y;
         /* z_t = lz[n23 / (m*n)]; */
         s_t = bases[n23] + i*x_t + k*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n23] + i*x_t;} /* 2d case */
@@ -939,6 +957,7 @@
         y_t = ly[(n24 % (m*n))/m];
         /* z_t = lz[n24 / (m*n)]; */
         s_t = bases[n24] + i*x_t - s_x + k*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n24] + i*x_t - s_x;} /* 2d case */
       if (n25 >= 0) { /* directly above */
@@ -946,6 +965,7 @@
         y_t = ly[(n25 % (m*n))/m];
         /* z_t = lz[n25 / (m*n)]; */
         s_t = bases[n25] + (i-1)*x_t + k*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n25] + (i-1)*x_t;} /* 2d case */
       if (n26 >= 0) { /* right above */
@@ -953,6 +973,7 @@
         y_t = ly[(n26 % (m*n))/m];
         /* z_t = lz[n26 / (m*n)]; */
         s_t = bases[n26] + (i-1)*x_t + k*x_t*y_t;
+        if (s_t >= x*y*z) {s_t = bases[n26] + (i-1)*x_t;} /* 2d case */
