[petsc-dev] [petsc-maint #69143] petsc-dev performance issues
Mon Apr 18 08:24:16 CDT 2011
   Matt,
     Yes, this is the problem.  Since we cannot know if anyone has called a PetscSynchronizedPrintf() it has to call this flush to be safe and that, to be safe, has to have the extra message passing. Even if we handle 1,000 processes at a time, with 100,000 processes it will take 100 stages which is too long.
     I think we have to do a major rearchitecturing.  Maybe we want to have a flag (set to false by default) in each ASCII viewer indicating that it has synchronize prints. When the flag is false it skips the entire flush and if a synchronize print is done it generates an error. We'll that is easily done.
    Barry
On Apr 18, 2011, at 8:10 AM, Matthew Knepley wrote:
> On Mon, Apr 18, 2011 at 7:52 AM, Sebastian Steiger <steiger at purdue.edu>wrote:
>> On 4/18/2011 7:25 AM, Matthew Knepley wrote:
>>> On Sun, Apr 17, 2011 at 11:59 PM, Sebastian Steiger <steiger at purdue.edu
>>> 17631 is in
>>> PetscSynchronizedFlush(), a routine which is not called from
>>>  KSPMonitorDefault()
>>>  --->  PetscViewerASCIIMonitorPrintf()
> I am looking over the code, and I think that change is going to be bad for
> everyone
> because we have
>  PetscViewerFlush_ASCII()
>  --> PetscSynchronizedFlush()
>       --> ping-pong between 0 and everyone
> Anytime someone calls flush, the process cannot just send 0 and move on, it
> has
> to wait.
>    Matt
>>> and thus would not change the performance. My guess is that you have
>> another
>>> print statement using PetscSynchronizedPrintf/Flush() somewhere in the
>> code.
>>>    Matt
>> In addition to the KSPMonitor, I've hooked up the petsc output with my
>> own output system as it is written on the webpage:
>> PetscErrorCode my_double_petsc_vfprintf(FILE * fd, const char format[],
>> va_list Argp)
>>       PetscErrorCode ierr;
>>       //PetscFunctionBegin; // <ss> gave problems in petsc-3.2 - not
>> essential according to Barry and Matt
>>       if (fd != stdout && fd != stderr) { /* handle regular files */
>>               ierr = PetscVFPrintfDefault(fd,format,Argp);
>> PetscMatrixNemo<double>::check_petsc_error(ierr);
>>       } else {
>>               char buff[2000];
>> #if PETSC_VERSION_RELEASE == 1
>>                int length;
>> #else
>>               size_t length;
>> #endif
>>               ierr = PetscVSNPrintf(buff, 2000, format, &length, Argp);
>>               /* now send buff to whatever stream or whatever you want */
>>               msg << buff;
>>               // flush buffer every 2nd time
>>               num_double_petsc_lines++;
>>               if (num_double_petsc_lines==2) {
>>                       msg.flush();
>>                       num_double_petsc_lines = 0;
>>       //PetscFunctionReturn(0);
>>       return 0;
>> Is that connected to the problem? Please note that the "flush buffer
>> every 2nd time" does not cause the problems, as it is on my side.
>> Sebastian
>>>    Sebastian
>>>    On 4/17/2011 9:16 PM, Barry Smith wrote:
>>>> On Apr 17, 2011, at 8:11 PM, Matthew Knepley wrote:
>>>>> On Sun, Apr 17, 2011 at 8:05 PM, Barry Smith <bsmith at mcs.anl.gov
>>>    <mailto:bsmith at mcs.anl.gov>> wrote:
>>>>> I don't understand, what is different and why does it slow
>>>    everything down?
>>>>> You introduced a ping-pong between 0 and every process for every
>>>    call to
>>>>> PetscSynchronizedFlush() in order to "stop a flood of messages to
>>>    0". As
>>>>> process count increases, this is going to be horrible.
>>>>   Oh yes, this will do it   Is this being used by one of our
>>>    monitor routines? If so we need to fix our monitors to not use
>>>    synchronized printf. So what in the code is calling this.
>>>>> This is just the kind of thing that MPI should be solving for us,
>>>    instead of us
>>>>> putting in bullshit code like this to try and regulate message
>>>    counts. Is there
>>>>> an MPI construct to manage this?
>>>>   One could use some kind of all to one to get the messages down
>>>    to process zero.
>>>>   Barry
>>>>>   Matt
>>>>>  Barry
>>>>> On Apr 17, 2011, at 6:50 PM, Sebastian Steiger wrote:
>>>>>> Barry, Matt, Satish,
>>>>>> Found it. r16730 is good, r16731 is bad. Matt was right: when I
>>>    turn off
>>>>>> the petsc messages generated by monitoring the iterations of the
>>>    linear
>>>>>> solver, then the revisions have comparable speed. When I turn it
>> on,
>>>>>> then 16731 is 2-3 times slower.
>>>>>> Please fix!
>>>>>> Best
>>>>>> Sebastian
>>>>>> On 04/15/2011 07:31 AM, Matthew Knepley wrote:
>>>>>>> On Thu, Apr 14, 2011 at 11:33 PM, Satish Balay
>>>    <petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
>>>    <mailto:petsc-maint at mcs.anl.gov>>> wrote:
>>>>>>>   It would be good to complete the bisection to confirm - but
>>>    could it
>>>>>>>   be this?
>>>>>>>   http://petsc.cs.iit.edu/petsc/petsc-dev/rev/10be2c80ec26
>>>>>>>   CHKMEMQ is disabled only with --with-errorchecking=0 - but
>> the
>>>>>>>   assumpton for this change was that it would be disabled for
>>>>>>>   --with-debugging=0 ?
>>>>>>> This is my bet for bad set:
>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/ee1bdc170b4d
>>>>>>> It introduces new messages, but only of length 1. Is your code
>>>    printing
>>>>>>> anything at all
>>>>>>> during the run?
>>>>>>>  Thanks,
>>>>>>>     Matt
>>>>>>>   Satish
>>>>>>>   On Thu, 14 Apr 2011, Sebastian Steiger wrote:
>>>>>>>> I'm sorry, actually 16721 is good and 16733 is bad. So it's 12
>>>>>>>   revisions.
>>>>>>>> On 4/14/2011 9:12 PM, Sebastian Steiger wrote:
>>>>>>>>> Hi,
>>>>>>>>> I've pinned it down to 16 revisions: 16721 is good, 16737 is
>>>>>>>   bad. The
>>>>>>>>> next bisection step would be 16727, but from the log I see
>> that
>>>>>>>>> 16727-16736 might have some problems. Should I continue or do
>>>>>>>   you guys
>>>>>>>>> now have a clue what could cause the factor 2-3 slowdown?
>>>>>>>>> Sebastian
>>>     steiger at jaguarpf-login6
>> :~/src/app-nemo/NEMO/libs/petsc-dev/petsc-dev$
>>>    hg
>>>>>>>>> log -r16721:16737
>>>>>>>>> changeset:   16721:b788c229de4d
>>>>>>>>> parent:      16720:9aafffdcf68b
>>>>>>>>> parent:      16715:e53f46924236
>>>>>>>>> user:        Jed Brown <jed at 59A2.org>
>>>>>>>>> date:        Mon Aug 09 17:30:28 2010 -0800
>>>>>>>>> summary:     merge
>>>>>>>>> changeset:   16722:4ca941c57754
>>>>>>>>> user: hong at vis-v410v166.mcs.anl-external.org
>>>    <mailto:hong at vis-v410v166.mcs.anl-external.org>
>>>    <mailto:hong at vis-v410v166.mcs.anl-external.org>>
>>>>>>>>> date:        Tue Aug 10 11:57:11 2010 -0500
>>>>>>>>> summary:     add case of np=1 for
>> MatGetMultiProcBlock_MPIAIJ()
>>>>>>>>> changeset:   16723:4d6b54981472
>>>>>>>>> date:        Tue Aug 10 12:00:14 2010 -0500
>>>>>>>>> summary:     fix memory leak in MatHeaderCopy() and
>>>>>>>   MatHeaderReplace()
>>>>>>>>> changeset:   16724:2680bde1c9b8
>>>>>>>>> user: Shri at mcswl165.mcs.anl.gov
>>>    <mailto:Shri at mcswl165.mcs.anl.gov> <mailto:Shri at mcswl165.mcs.anl.gov
>>>    <mailto:Shri at mcswl165.mcs.anl.gov>>
>>>>>>>>> date:        Thu Aug 12 14:37:43 2010 -0500
>>>>>>>>> summary:     Started adding semismooth stuff.
>>>>>>>>> changeset:   16725:50dceda7151c
>>>>>>>>> date:        Thu Aug 12 14:45:13 2010 -0500
>>>>>>>>> summary:     Defined Infinity and epsilon
>>>>>>>>> changeset:   16726:c0f1b46d675f
>>>>>>>>> user:        hzhang
>>>>>>>>> date:        Fri Aug 13 11:10:37 2010 -0500
>>>>>>>>> summary:     update outputfiles for nightly tests
>>>>>>>>> changeset:   16727:67df4fdba5bd
>>>>>>>>> user: hong at hzhangmac.mcs.anl.gov
>>>    <mailto:hong at hzhangmac.mcs.anl.gov>
>>>    <mailto:hong at hzhangmac.mcs.anl.gov>>
>>>>>>>>> date:        Fri Aug 13 13:25:56 2010 -0500
>>>>>>>>> summary:     add PetscSubcommType in PetscSubcommCreate(); add
>>>>>>>>> PetscSubcommCreate_contiguous().
>>>>>>>>> changeset:   16728:10be2c80ec26
>>>>>>>>> parent:      16723:4d6b54981472
>>>>>>>>> user:        Barry Smith bsmith at mcs.anl.gov
>>>>>>>   <mailto:bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>>>>>>>> date:        Tue Aug 10 18:15:10 2010 -0500
>>>>>>>>> summary:     merged CHKMEMQ; into PetscStackPush() and
>>>>>>>   PetscStackPop()
>>>>>>>>> changeset:   16729:ef8e7a4583e6
>>>>>>>>> date:        Thu Aug 12 14:16:40 2010 -0500
>>>>>>>>> summary:     changed MatHeaderCopy() to MatHeaderMerge() and
>>>>>>>   improved
>>>>>>>>> comment
>>>>>>>>> changeset:   16730:50055ed8b725
>>>>>>>>> parent:      16729:ef8e7a4583e6
>>>>>>>>> parent:      16725:50dceda7151c
>>>>>>>>> date:        Thu Aug 12 16:24:48 2010 -0500
>>>>>>>>> summary:     commit after merge
>>>>>>>>> changeset:   16731:ee1bdc170b4d
>>>>>>>>> date:        Fri Aug 13 13:50:30 2010 -0500
>>>>>>>>> summary:     minor formating of short lines
>>>>>>>>> changeset:   16732:a49d9a4b41bc
>>>>>>>>> parent:      16731:ee1bdc170b4d
>>>>>>>>> parent:      16727:67df4fdba5bd
>>>>>>>>> date:        Fri Aug 13 13:50:43 2010 -0500
>>>>>>>>> changeset:   16733:804ce43d15c9
>>>>>>>>> date:        Fri Aug 13 11:01:24 2010 -0800
>>>>>>>>> summary:     Update converged reason for Rosenbrock demo to be
>>>>>>>   more portable
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to
>>>    which
>>>>>>> their experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> <bisection-conclusion.txt>
>>>    experiments is infinitely more interesting than any results to which
>>>>> -- Norbert Wiener
>>> -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
> On Mon, Apr 18, 2011 at 7:52 AM, Sebastian Steiger <steiger at purdue.edu> wrote:
> > <mailto:steiger at purdue.edu>> wrote:
> >     On a side note, why did that PetscPrintf function not show up in the log
> >     summary? That could have spared me the whole bisection process.
> > I cannot make sense of the problem from your report. The only change in
> > 17631 is in
> >   KSPMonitorDefault()
> I am looking over the code, and I think that change is going to be bad for everyone
> because we have
> Anytime someone calls flush, the process cannot just send 0 and move on, it has
> to wait.
>     Matt
> > and thus would not change the performance. My guess is that you have another
> > print statement using PetscSynchronizedPrintf/Flush() somewhere in the code.
> >     Matt
> va_list Argp)
>        } else {
>                char buff[2000];
>                int length;
> #else
>                size_t length;
> #endif
>                msg << buff;
>                        msg.flush();
>        return 0;
> Sebastian
> >     Sebastian
> >     everything down?
> >     call to
> >     0". As
> >     instead of us
> >     counts. Is there
> >     to process zero.
> >     >    Barry
> >     >>    Matt
> >     >>   Barry
> >     turn off
> >     linear
> >     >>> solver, then the revisions have comparable speed. When I turn it on,
> >     >>> Please fix!
> >     >>> Best
> >     >>> Sebastian
> >     could it
> >     >>>>    be this?
> >     >>>>    CHKMEMQ is disabled only with --with-errorchecking=0 - but the
> >     printing
> >     >>>> anything at all
> >     >>>> during the run?
> >     >>>>   Thanks,
> >     >>>>      Matt
> >     >>>>    Satish
> >     >>>>    revisions.
> >     >>>>>> Hi,
> >     >>>>    bad. The
> >     >>>>>> next bisection step would be 16727, but from the log I see that
> >     >>>>    you guys
> >     >>>>>> Sebastian
> >      steiger at jaguarpf-login6:~/src/app-nemo/NEMO/libs/petsc-dev/petsc-dev$
> >     hg
> >     >>>>>> log -r16721:16737
> >     >>>>>> summary:     merge
> >     >>>>>> summary:     add case of np=1 for MatGetMultiProcBlock_MPIAIJ()
> >     >>>>    MatHeaderReplace()
> >     >>>>>> user:        hzhang
> >     >>>>    PetscStackPop()
> >     >>>>    improved
> >     >>>>>> comment
> >     >>>>    more portable
> >     which
> >     >>>> -- Norbert Wiener
> >     >> -- Norbert Wiener
> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
