[petsc-dev] Compilation error with umfpack.c
Vijay S. Mahadevan vijay.m at gmail.com
Mon Apr 11 10:17:43 CDT 2011
Jed,
My UMFPACK version was V5.4.0 (May 20, 2009). I've removed the umfpack
directory and have reconfigured. And make went through successfully !
Thanks for the quick reply.
Vijay
On Mon, Apr 11, 2011 at 10:09 AM, Jed Brown <jed at 59a2.org> wrote:
> On Mon, Apr 11, 2011 at 17:00, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Hi,
>> I am working with the development version of petsc and updated the
>> files recently. After reconfiguration, make gave the following errors.
> changeset:   18670:8990aa4897ee
> user:        Jed Brown <jed at 59A2.org>
> date:        Sat Mar 26 12:24:03 2011 +0300
> summary:     Update Umfpack interface to 5.5.1
> You need to use Umfpack-5.5.1 with petsc-dev. If you installed Umfpack with
> --download-umfpack, then you should
> rm -r $PETSC_ARCH/conf/UMFPACK $PETSC_ARCH/include/umfpack*
> $PETSC_ARCH/lib/libumfpack* externalpackages/UMFPACK*
> and reconfigure.
