[petsc-dev] Index sets in MatCreateNest
Thomas Witkowski thomas.witkowski at tu-dresden.de
Mon Apr 11 01:43:56 CDT 2011
Could some of you give me a short explanation, what the index sets in
MatCreateNest can be used for? I already had a look to the examples and
tests, but all of them just put PETSC_NULL for the index sets or create
the standard contiguous index sets by hand
(ksp/ksp/example/tests/ex11.c). Does the index sets influence the
row/column indices for the final MatNest? The reason why I'm asking for
is that I want to have a special order in my MatNest. My scenario is as
follows: I have a 2x2 MatNest. The first block corresponds to all
interior nodes on all subdomains. The second block corresponds to the
boundary nodes between all subdomains. This works fine, also with the
fieldsplit preconditioner! Now I would like to permute the global index
of the second block in that way, that all edge boundary nodes are listed
first and finally all vertex boundary nodes (its a 2D problem). So each
rank local matrix of the second block is no more contiguous. I'm not
sure, if I need to change the creation of the second block matrix or the
creation of the nested matrix. I thought may be it is possible to do it
with the index sets when creating the MatNest?
Thomas
