[petsc-dev] Compiling C code with C compiler
Sean Farley sean at mcs.anl.gov
Mon Apr 4 21:25:39 CDT 2011
> What did you expect when you used --with-clanguage=C++ for your buid? Or
> were you misunderstanding what this options means wrt PETSc build?
I understand what it was trying to do but it is necessary for sieve
(especially with certain mesh generators). Why does all of PETSc need to be
compiled with C++ in order to use sieve is the real question?
.c -> compiled with mpicc
.cxx -> compiled with mpicxx
Is there something else missing? (Perhaps linking?)
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110404/e2e48507/attachment.html>
