[petsc-dev] Compiling C code with C compiler
Sean Farley sean at mcs.anl.gov
Mon Apr 4 20:33:20 CDT 2011
When specifying --with-clanguage=C++ (as required by sieve) all C code (any
.c file) is still compiled with the C++ compiler. This behavior is
deprecated as clang will warn you:
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior
is deprecated
C is not a subset of C++ and treats structs very differently than C++. This
should really be handled correctly but I can't read the conf/rules file no
more than I can read Greek.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110404/0c11e7c8/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110404/0c11e7c8/attachment.obj>
