[petsc-dev] What is this even supposed to do?
Wed Sep 8 08:52:39 CDT 2010
On Wed, Sep 8, 2010 at 3:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 8, 2010, at 4:14 AM, Jed Brown wrote:
> > "to" is uninitialized here, it can't possibly work.
> > PetscErrorCode PETSCMAP1(VecScatterBegin)(VecScatter ctx,Vec xin,Vec
> yin,InsertMode addv,ScatterMode mode)
> >  VecScatter_MPI_General *to,*from;
> >  PetscScalar            *xv,*yv,*svalues;
> >  MPI_Request            *rwaits,*swaits;
> >  PetscErrorCode         ierr;
> >  PetscInt               i,*indices,*sstarts,nrecvs,nsends,bs;
> >  PetscFunctionBegin;
> > #if defined(PETSC_HAVE_CUDA)
> >  if (xin->valid_GPU_array == PETSC_CUDA_GPU) {
> >    if (!ctx->spptr) {
> >      PetscInt *indices,n = to->n;
> >      ierr = PetscMalloc(n*sizeof(PetscInt),&indices);CHKERRQ(ierr);
> >      ierr =
> PetscMemcpy(indices,to->indices,n*sizeof(PetscInt));CHKERRQ(ierr);
> >      ierr = PetscSortRemoveDupsInt(&n,indices);CHKERRQ(ierr);
> >      ierr = PetscIntView(n,indices,0);CHKERRQ(ierr);
> >      ierr = PetscFree(indices);CHKERRQ(ierr);
> >  } else {
> >    ierr = VecGetArrayRead(xin,(const PetscScalar**)&xv);CHKERRQ(ierr);
> > #else
> > #endif
> > The PETSC_HAVE_CUDA block was added by
> >  changeset:   16792:571800d0bf67
> >  parent:      16784:e7052ddd3def
> >  user:        Barry Smith bsmith at mcs.anl.gov
> >  date:        Mon Aug 23 18:37:40 2010 -0500
> >  summary:     better message in check of positive definite shift for ILU
> > With commit messages like these...
>   Sorry, my fault. It is because I don't have a decent hg commit tool that
> tells me what I changed so I can comment on it.
Mac Hg! It rocks. Did you have an installation problem?
   Matt
>   Yes that code is currently broken, I started in and then got distracted
> and didn't finish it. You can just stick it inside a #if defined(foo) for
> now.
>   Barry
> > This can probably just get relocated to later in the function (after
> > "to" is resolved), but I hear that CUDA works (I'm fighting with a
> > broken CUDA environment at the moment), in which case this branch must
> > never be taken, so it should just be deleted.
> > Jed
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100908/2e6c8850/attachment.html>
