[petsc-dev] Where is the PETSC_INCLUDE?
Yan Yan yy2250 at columbia.edu
Tue Nov 30 12:24:47 CST 2010
Dear All,
I was using petsc-3.1-p0, and there is a variable called PETSC_INCLUDE under
/home/yyan/local/petsc-3.1-p0/conf. This
variable is useful for me to do the linking...
Now, I switched to petsc-dev version and I realized that this variable is no
longer there:
/home/yyan/local/petsc-dev/conf
The change set # is:(I do not have mercurial on this machine...)
petsc-dev-19ff411a783e.tar.gz
BuildSystem-de5cd087d2fe.tar.gz
So could you tell me where I can find this variable or it's substitute?
Many thanks,
Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101130/cefb3e0c/attachment.html>
