[petsc-dev] Need a new name for DMDAGetOwnershipRanges
Jed Brown jed at 59A2.org
Mon Nov 29 15:58:10 CST 2010
Lisandro just pointed out that it does not return a range, which is indeed
confusing.  Two options:
1. Keep the current interface but find a better name.  Low impact on users.
2. Keep the name, and make it return offset arrays of length m+1,n+1,p+1
(the closest analogy to Vec and mat OwnershipRanges).  Higher impact on
users, would require revisiting a decent amount of code in DA, but probably
not in a deep way.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101129/ff522a83/attachment.html>
