[petsc-dev] .dir-locals.el
Wed Nov 24 10:37:05 CST 2010
  Sean,
   Thanks, I'm up to Emacs version 23 now and living with Jed's strange file.
   Barry
On Nov 23, 2010, at 11:09 PM, Sean Farley wrote:
> Either way, it seems there is a fix if you set "ns-pop-up-frames" to nil. See this thread:
> http://permalink.gmane.org/gmane.emacs.devel/128939
> and he is quoting David Reitter from here:
> http://comments.gmane.org/gmane.emacs.devel/125714
> Just to follow-up, I can confirm this works. If you add:
> ;; always open in the same window
> (setq ns-pop-up-frames nil)
> to your ~/.emacs file then:
> $ open -a Emacs file
> will open the file in the current window.
> Sean
