[petsc-dev] MatGetLocalSubMatrix, MatLocalReference implementation
Sat Nov 20 17:01:15 CST 2010
  Jed,
   Just pick what you want, but if you do use "local" then it should match the use of "local" in other parts of PETSc (for example a local Vec is a ghosted "part" of a global Vec). For example, if you suddenly starting calling unghosted sequential Vec parts of a global Vec it would be confusing. So just use your judgement, I can't tell what you are asking half the time so don't always expect a coherent response.
   Barry
On Nov 20, 2010, at 1:49 AM, Jed Brown wrote:
> Your function is returning objects with global semantics (they live on the global comm). The other local functions return objects that are semantically serial, although they may be logically part of something bigger. But why return an IS at all, why not an ISLocalToGlobalMapping? Too many characters?
> I need a name for a local IS that holds indices in a local numbering. This thing has no parallel semantics, just like a local Vec. The term "local IS" is not currently taken, if we don't count you man page. Would it be acceptable to use it for my purpose?
> Jed
>> On Nov 20, 2010 4:15 AM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>> On Nov 19, 2010, at 6:43 PM, Jed Brown wrote:
>> > Jed
>> > [1] Barry, what is going on with DMCom...
>>   Looks like code that was started (maybe from cut and paste) and never finished. The manual page for function has a different name then the function, like I just stopped in the middle of editing and forgot about it.
>> > The former has no implementation and the
>> > latter has no man page. I do not think that "Local IS"...
>>   Well no. Local always refers to things with ghost points, while global means without ghost points. You are asking to introduce another term "Ghosted" to mean with ghost points.  Confusing/bad to introduce more terminology.
>>   Now you could argue that using local and global was bad originally and we should use ghosted and global (or nonghosted) as our two terms. But introducing ghosted in just one place is not the solution, we would have to do it systematically through PETSc source and documentation. Though I think local and global are fine as is and don't see a need to change from local to ghosted.
>>  Or I could be misunderstanding what you want to change.
>>   Barry
