[petsc-dev] MatGetLocalSubMatrix, MatLocalReference implementation
Jed Brown jed at 59A2.org
Thu Nov 18 18:42:07 CST 2010
In this direction, I need to be able to handle the off-diagonal local parts,
which implies logically distinct row mappings and column mappings.  It seems
like it should have been that way all along and I will make it so (tomorrow)
unless there are objections.  This implies two parameters in
MatSetLocalToGlobalMapping, but I think that is the only API change.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101119/9fb3b95b/attachment.html>
