[petsc-dev] IS updates breaking some fortran tests
Wed Nov 17 17:02:57 CST 2010
src/vec/examples/tests/ex1f runs fine for me.
Do you have an old/broken sowing/bfort? Have you regenerated fortranstubs
with the new bfort [which knows the PetscTruth->PetscBool change?]
Satish
On Wed, 17 Nov 2010, Dmitry Karpeev wrote:
> I just pushed an IS update that causes problems in some fortran tests.
> I'm not sure exactly what's going on, but a failure occurs, for
> example, in src/vec/examples/tests/ex1f
> in VecValid.  Looked at with a debugger it reveals that 'flg', a
> pointer to boolean that is being passed from Fortran
> to C, is wiped out and emerges as NULL on the C side (I assume, upon a
> cast; since there is no temporary
> in vecvalid_ that holds the result of the "cast", I can't really
> examine the intermediate value passed to C).
> I've been trying to figure this out for a bit, but have come up with
> nothing so far (e.g., valgrind runs on ex1f fine).
> I'm sure this will show up in the nightly builds, but I figured I'd
> push this change, hoping that someone with a
> better knowledge of Fortran bindings will help me figure this out.
> Thanks.
> Dmitry.
