[petsc-dev] Fwd: HDF5: all of that for...
Tue Nov 16 14:12:16 CST 2010
  No, we support HDF5 for vectors because it makes sense; other packages can read them in and do things with them (for example visualization). We don't support HDF5 for matrices cause it doesn't make much sense. Just use the Petsc binary viewers if you want to save PETSc matrices (though even doing that should be rarely needed), HDF5 won't be any faster.
   Barry
On Nov 16, 2010, at 2:07 PM, Srinath Vadlamani wrote:
> Is it possible to write out MPIAJ matrices to hdf5 via the viewer?
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Viewer type hdf5 not supported by MPIAIJ matrices!
> <>Srinath
> Srinath Vadlamani, PhD.
> Tech-X Corp. Research Scientist
> 5621 Arapahoe Ave. Suite A
> Boulder, CO 80303
> 303-996-2034
