[petsc-dev] Fwd: [petsc-maint #56111] petsc4py does not work with complex numbers?
Tue Nov 16 07:40:45 CST 2010
  Satish,
   Valgrind ok?
   Barry
On Nov 16, 2010, at 7:23 AM, Satish Balay wrote:
> With '-fp_trap -start_in_debugger' in ~/.petscrc, I get a crash at:
> Program received signal SIGFPE, Arithmetic exception.
> 0x00007f86e5ee17b4 in ATL_zreftrsmLLNN () from /usr/lib64/atlas/libatlas.so.3
> (gdb) where
> #0  0x00007f86e5ee17b4 in ATL_zreftrsmLLNN ()
> #1  0x00007f86e5efc9fb in ATL_ztrsmLLNN () from /usr/lib64/atlas/libatlas.so.3
> #2  0x00007f86e5efc4e1 in ATL_ztrsm () from /usr/lib64/atlas/libatlas.so.3
> #3  0x000000394422ebbc in ATL_zpotrs () from /usr/lib64/atlas/liblapack.so.3
> #4  0x00000039446a69cb in zpotrs_ () from /usr/lib64/atlas/liblapack.so.3
> #5  0x00007f86e71df480 in KSPSolve_BCGSL (ksp=0x1372da0) at bcgsl.c:179
> #6  0x00007f86e74dbd1e in KSPSolve (ksp=0x1372da0, b=0x13a9c30, x=0x13a5b20)
>    at itfunc.c:427
> #7  0x00007f86e7ef5898 in __pyx_pf_8petsc4py_5PETSc_3KSP_solve (
>    __pyx_v_self=0xc8e090, __pyx_args=<value optimized out>,
>    __pyx_kwds=<value optimized out>) at src/petsc4py.PETSc.c:89419
> 179           LAPACKpotrs_("Lower", &bell, &ione, &MZa[1+ldMZ], &ldMZ, &AY0c[1], &ldMZ, &bierr);
> (gdb) p ldMZ
> $1 = 3
> (gdb) p ldMZ
> $2 = 3
> (gdb) p MZa[1+ldMZ]
> $3 = 2.1147927874194505e-14 + 0 * I
> (gdb) p MZa[1+ldMZ+1]
> $4 = 2.1147927874194505e-14 + 0 * I
> (gdb) p MZa[1+ldMZ+2]
> $5 = 4.472348533721329e-28 + -0 * I
> (gdb) p AY0c[1]
> $6 = 2.1147927874194505e-14 + 0 * I
> (gdb) p AY0c[2]
> $7 = 0 + 0 * I
> (gdb) p AY0c[3]
> $8 = 1.9966503766457982e-314 + 9.5700515599449456e-321 * I
> (gdb)
> So - perhaps some of these values are garbage - generated in earler
> part of the code?  I don't know where the bug is yet..
> [BTW: VecEqual fix is pushed to both petsc-31 and petsc-dev]
> Satish
> On Mon, 15 Nov 2010, Lisandro Dalcin wrote:
>> petsc-dev has a bug in VecEqual for the case of complex scalars. I've
>> mailed Satish about this with a single-line patch. After applying the
>> patch, almost all petsc4py tests pass.
>> Still, there is a failure, but I doubt it is petsc4py's fault:
>> ERROR: testSolve (test_ksp.TestKSPBCGSL)
>> Traceback (most recent call last):
>>  File "test/test_ksp.py", line 132, in testSolve
>>    self.ksp.solve(b, x)
>>  File "KSP.pyx", line 326, in petsc4py.PETSc.KSP.solve
>> (src/petsc4py.PETSc.c:89520)
>> Error: error code 62
>> [0] KSPSolve() line 427 in /usr/local/petsc/dev/src/ksp/ksp/interface/itfunc.c
>> [0] KSPSolve_BCGSL() line 241 in
>> /usr/local/petsc/dev/src/ksp/ksp/impls/bcgsl/bcgsl.c
>> [0] VecMAXPY() line 1202 in /usr/local/petsc/dev/src/vec/vec/interface/rvector.c
>> [0] Invalid argument
>> [0] Scalar value must be same on all processes, argument # 3
>> On 15 November 2010 20:05, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Ok. For now - I've added complex=1 for petsc4py.py [and mpi4py.py]
>>> Satish
>>>> On 15 November 2010 19:01, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> I get the following with complex enabled. Does this mean 'some tests
>>>>> run but others fail'?
>>>>> I guess we'll have to wait for Lisandro to reply..
>>>> Complex numbers should work just fine, at least with 3.1, I'm going to
>>>> check against petsc-dev.
>>>>> asterix:/home/balay/tmp/petsc-dev/externalpackages/petsc4py-dev>make test
>>>>> python test/runtests.py < /dev/null
>>>>> [0 at asterix] Python 2.7 (/usr/bin/python)
>>>>> [0 at asterix] PETSc 3.1.0-p5 development (conf: 'asterix64')
>>>>> [0 at asterix] petsc4py 1.1.2 (build/lib.linux-x86_64-2.7/petsc4py)
>>>>> .......................................................................................................................................................................................................................EE...................................................................................................F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F
>>>>>  .F........F........F........F.........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F........F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F..F...................FE..........FF.FEF...........F.....................................................................................................................................................................................................................FFFF........FFFF................................................................F...F..F.......F...F..F.......F...F..F........
>>>>> ERROR: testSetMonitor (test_ksp.TestKSPBCGSL)
>>>>>  File "test/test_ksp.py", line 154, in testSetMonitor
>>>>>    self.testSolve()
>>>>>  File "KSP.pyx", line 326, in petsc4py.PETSc.KSP.solve (src/petsc4py.PETSc.c:89419)
>>>>> [0] KSPSolve() line 427 in src/ksp/ksp/interface/itfunc.c
>>>>> [0] KSPSolve_BCGSL() line 241 in src/ksp/ksp/impls/bcgsl/bcgsl.c
>>>>> [0] VecMAXPY() line 1202 in src/vec/vec/interface/rvector.c
>>>>> ERROR: testCreateTranspose (test_mat_py.TestDiagonal)
>>>>>  File "test/test_mat_py.py", line 100, in tearDown
>>>>>    self.assertEqual(getrefcount(ctx), 2)
>>>>> AssertionError: 3 != 2
>>>>> ERROR: testMultTransposeNewMeth (test_mat_py.TestIdentity)
>>>>> On Mon, 15 Nov 2010, Barry Smith wrote:
>>>>>>>    Could someone who knows answer this? If it supports complex then we'll need to change the flag in petsc4py.py
>>>>>>>   Barry
>>>>>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
>>>>>>> Cannot use petsc4py with complex numbers it is not coded for this capability
>>>>>>>   File "./config/configure.py", line 260, in petsc_configure
>>>>>>>     framework.configure(out = sys.stdout)
>>>>>>>   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/BuildSystem/config/framework.py", line 977, in configure
>>>>>>>     child.configure()
>>>>>>>   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/BuildSystem/config/package.py", line 488, in configure
>>>>>>>     self.consistencyChecks()
>>>>>>>   File "/Users/srinath/work/Packages/rev-packages/petsc-dev/config/PETSc/package.py", line 40, in consistencyChecks
>>>>>>>     raise RuntimeError('Cannot use '+self.name+' with complex numbers it is not coded for this capability')
>>>>>>> Begin forwarded message:
>>>>>>>> From: Srinath Vadlamani <srinath at txcorp.com>
>>>>>>>> Date: November 15, 2010 3:27:55 PM CST
>>>>>>>> To: petsc-maint <petsc-maint at mcs.anl.gov>
>>>>>>>> Subject: [petsc-maint #56111] petsc4py does not work with complex numbers?
>>>>>>>> Reply-To: petsc-maint at mcs.anl.gov, Srinath Vadlamani <srinath at txcorp.com>
>>>>>>>> Is this true?
>>>>>>>> Srinath Vadlamani, PhD.
>>>>>>>> Tech-X Corp. Research Scientist
>>>>>>>> 5621 Arapahoe Ave. Suite A
>>>>>>>> Boulder, CO 80303
>>>>>>>> 303-996-2034
>>>>>>>> Is this true?
>>>>>>>> Boulder, CO 80303
>>>>>>>> 303-996-2034
