[petsc-dev] error with build
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 15 16:43:51 CST 2010
On 15 November 2010 18:53, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Here is that part of the makefile. So I guess the answer is, yes it should all just work but I don't know why it doesn't.
That "makefile" is NOT intended to be petsc4py buildsystem. I use it
as a convenience for my everyday hacking.
> Or maybe it does. It would help if petsc4py was properly in the nightly builds! Or is it?
Not sure if BuildSystem handles the hg pull of petsc4py-dev ....
>   Barry
> CY_SRC_PXD = $(wildcard src/include/petsc4py/*.pxd)
> CY_SRC_PXI = $(wildcard src/PETSc/*.pxi)
> CY_SRC_PYX = $(wildcard src/PETSc/*.pyx)
> src/PETSc.c: src/petsc4py.PETSc.c
> src/petsc4py.PETSc.c: ${CY_SRC_PXD} ${CY_SRC_PXI} ${CY_SRC_PYX}
>        ${PYTHON} ./conf/cythonize.py
> On Nov 15, 2010, at 3:44 PM, Jed Brown wrote:
>> On Mon, Nov 15, 2010 at 22:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> It will run cython the FIRST time after a clone but not after a hg pull. Which is wrong.  I would like to see this code check if it is a .hg repository (for example) and always run cython in that case.
>> Is it somehow not possible to write correct Make dependencies for cython?
>> Jed
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
