[petsc-dev] error with build
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 15 16:39:59 CST 2010
On 15 November 2010 18:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   It will run cython the FIRST time after a clone but not after a hg pull. Which is wrong.  I would like to see this code check if it is a .hg repository (for example) and always run cython in that case.
>   Lisandro, is that something that could be added?
Yep, adding a bit of dependency handling (based on timestamps, like
make) would not be that hard, Python's distutils even has some
utilities to do this.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
