[petsc-dev] error with build
Mon Nov 15 15:11:42 CST 2010
   There (sadly) is not completely automatic way to do this. Cd to $PETSC_DIR/externalpackages; remove any petsc4py* directories from there; clone petsc4py-dev into that directory. cd back to $PETSC_DIR; now run ./configure --download-petsc4py
   It will not go and get a copy of petsc4py since the petsc4py-dev directory exists, rather it will use the one you have put there (by your clone).
   Note that petsc4py-dev may not always have been updated to the latest changes to petsc-dev, if you get errors in the build report them to petsc-maint at mcs.anl.gov and we'll update the petsc4py-dev; note that after an update of petsc4py-dev you should cd externalpackages/petsc4py-dev and hg pull; hg update to get the latest.
  Yes, someone should add proper support for ./configure to handle hg repositories from petsc-dev and do the pulls and updates automatically but that code has not been written, hence the manual process.
   Barry
On Nov 15, 2010, at 3:00 PM, Srinath Vadlamani wrote:
> How does one configure petsc-dev to build petsc4py-dev?
> I cloned petsc4py-dev but it needs my petsc-dev complex install to have petsc4py symbols?
> <>Srinath
> 2010/11/15 Satish Balay <balay at mcs.anl.gov>
> [original e-mail didnt make it to the list due to the attached
> configure.log. Huge attachments are prohibited on the mailing lists]
> Using configure Options: --with-petsc-arch=real-par-debug --with-scalar-type=real --with-debugging=yes --with-debugger=totalview --download-superlu_dist=1 --download-mumps=1 --download-spooles=1 --with-shared=1 --download-blacs=1 --download-parmetis=1 --download-szip=1 --download-scalapack=1 --download-petsc4py --download-mpi4py --with-shared-libraries -prefix=/Users/srinath/software/petsc-dev-real-par
> petsc4py listed in petsc4py.py is
> http://petsc4py.googlecode.com/files/petsc4py-1.1.1.tar.gz Perhaps you
> have to use petsc-4py-dev directly to get this working?
> Lisandro will know..
> Satish
> On Mon, 15 Nov 2010, Srinath Vadlamani wrote:
> > In file included from src/PETSc.c:3:
> > src/petsc4py.PETSc.c: In function
> > ‘__pyx_pf_8petsc4py_5PETSc_2IS_getBlockSize’:
> > src/petsc4py.PETSc.c:49179: warning: implicit declaration of function
> > ‘ISBlock’
> > src/petsc4py.PETSc.c: In function ‘__pyx_pf_8petsc4py_5PETSc_2IS_getInfo’:
> > src/petsc4py.PETSc.c:51132: warning: implicit declaration of function
> > ‘ISStride’
> > src/petsc4py.PETSc.c: In function ‘__pyx_pf_8petsc4py_5PETSc_3Mat_zeroRows’:
> > src/petsc4py.PETSc.c:75725: error: too few arguments to function
> > ‘MatZeroRowsIS’
> > src/petsc4py.PETSc.c:75750: error: too few arguments to function
> > ‘MatZeroRows’
> > ‘__pyx_pf_8petsc4py_5PETSc_3Mat_zeroRowsLocal’:
> > src/petsc4py.PETSc.c:75872: error: too few arguments to function
> > ‘MatZeroRowsLocalIS’
> > src/petsc4py.PETSc.c:75897: error: too few arguments to function
> > ‘MatZeroRowsLocal’
> > ‘__pyx_pf_8petsc4py_5PETSc_3KSP_setConvergenceTest’:
> > src/petsc4py.PETSc.c:87471: error: ‘KSP_NORM_NO’ undeclared (first use in
> > this function)
> > src/petsc4py.PETSc.c:87471: error: (Each undeclared identifier is reported
> > only once
> > src/petsc4py.PETSc.c:87471: error: for each function it appears in.)
> > ‘__pyx_pf_8petsc4py_5PETSc_3KSP_getNormType’:
> > src/petsc4py.PETSc.c:88847: error: ‘KSP_NORM_NO’ undeclared (first use in
> > this function)
> > src/petsc4py.PETSc.c: In function ‘initPETSc’:
> > src/petsc4py.PETSc.c:131697: error: ‘KSP_NORM_NO’ undeclared (first use in
> > this function)
> > error: command 'mpicc' failed with exit status 1
> > make[1]: *** [petsc4py] Error 1
> Srinath Vadlamani, PhD.
> Tech-X Corp. Research Scientist
> 5621 Arapahoe Ave. Suite A
> Boulder, CO 80303
> 303-996-2034
