[petsc-dev] error with build
Mon Nov 15 13:03:32 CST 2010
[original e-mail didnt make it to the list due to the attached
configure.log. Huge attachments are prohibited on the mailing lists]
Using configure Options: --with-petsc-arch=real-par-debug --with-scalar-type=real --with-debugging=yes --with-debugger=totalview --download-superlu_dist=1 --download-mumps=1 --download-spooles=1 --with-shared=1 --download-blacs=1 --download-parmetis=1 --download-szip=1 --download-scalapack=1 --download-petsc4py --download-mpi4py --with-shared-libraries -prefix=/Users/srinath/software/petsc-dev-real-par
petsc4py listed in petsc4py.py is
http://petsc4py.googlecode.com/files/petsc4py-1.1.1.tar.gz Perhaps you
have to use petsc-4py-dev directly to get this working?
Lisandro will know..
Satish
On Mon, 15 Nov 2010, Srinath Vadlamani wrote:
> In file included from src/PETSc.c:3:
> src/petsc4py.PETSc.c: In function
> ‘__pyx_pf_8petsc4py_5PETSc_2IS_getBlockSize’:
> src/petsc4py.PETSc.c:49179: warning: implicit declaration of function
> ‘ISBlock’
> src/petsc4py.PETSc.c: In function ‘__pyx_pf_8petsc4py_5PETSc_2IS_getInfo’:
> src/petsc4py.PETSc.c:51132: warning: implicit declaration of function
> ‘ISStride’
> src/petsc4py.PETSc.c: In function ‘__pyx_pf_8petsc4py_5PETSc_3Mat_zeroRows’:
> src/petsc4py.PETSc.c:75725: error: too few arguments to function
> ‘MatZeroRowsIS’
> src/petsc4py.PETSc.c:75750: error: too few arguments to function
> ‘MatZeroRows’
> ‘__pyx_pf_8petsc4py_5PETSc_3Mat_zeroRowsLocal’:
> src/petsc4py.PETSc.c:75872: error: too few arguments to function
> ‘MatZeroRowsLocalIS’
> src/petsc4py.PETSc.c:75897: error: too few arguments to function
> ‘MatZeroRowsLocal’
> ‘__pyx_pf_8petsc4py_5PETSc_3KSP_setConvergenceTest’:
> src/petsc4py.PETSc.c:87471: error: ‘KSP_NORM_NO’ undeclared (first use in
> this function)
> src/petsc4py.PETSc.c:87471: error: (Each undeclared identifier is reported
> only once
> src/petsc4py.PETSc.c:87471: error: for each function it appears in.)
> ‘__pyx_pf_8petsc4py_5PETSc_3KSP_getNormType’:
> src/petsc4py.PETSc.c:88847: error: ‘KSP_NORM_NO’ undeclared (first use in
> this function)
> src/petsc4py.PETSc.c: In function ‘initPETSc’:
> src/petsc4py.PETSc.c:131697: error: ‘KSP_NORM_NO’ undeclared (first use in
> this function)
> error: command 'mpicc' failed with exit status 1
> make[1]: *** [petsc4py] Error 1
