[petsc-dev] Problem with latest "petsc-dev" change
Wed Nov 3 23:11:27 CDT 2010
On Wed, 3 Nov 2010, Bobby Philip wrote:
> As far as I can tell SAMRAI uses petsc assuming the C style calls
> for petsc.
Yeah - the issue comes up when building PETSc with a c compiler - and
then compiling user code [in this case SAMRAI] that includes petsc.h
with c++ compiler.
> In cases where I have enabled C++ in PETSc it has broken
> SAMRAI.
Are compiles broken or runs broken? If its compiles - perhaps its just
a matter of correct #defines [managing c/c++ lang when including
petsc?]
Satish
