[petsc-dev] Error building the latest PETSc
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 20:55:48 CDT 2010
Satish, Jed -- I'm not sure the message got through -- here's the info
without the log files:
On 11/03/2010 06:50 PM, Satish Balay wrote:*
>     I think I understand the issue. I'm pushing something that should fix it.
>     [so here - you have to do 'hg pull -u' to get this fix and rerun configure]
>     Jed,
>     The issue is: PETSc is built without a c++ compiler, but SAMRAI - is using it with c++ - hence the error [with missing PETSC_FUNCTION_NAME_CXX]. So I think we'll have to always set PETSC_FUNCTION_NAME_CXX irrespective of c++ usage in petsc.
>     Perhaps you might want to cleanup my fix..
Satish, Jed -- thanks for the fix -- I think we're almost there.
Here is an error I get from installing the latestpetsc-dev:
> libfast in:
> /home/cponder/CUDA/PFlotran/petsc-dev/src/sys/viewer/impls/hdf5
> hdf5v.c:298: error: conflicting types for ‘PetscViewerHDF5GetTimestep’
> /home/cponder/CUDA/PFlotran/petsc-dev/include/petscviewer.h:286: note:
> previous declaration of ‘PetscViewerHDF5GetTimestep’ was here
> /usr/bin/ar: hdf5v.o: No such file or directory
>   Error during compile, check arch-linux-gnu-c-debug/conf/make.log
>   Send it and arch-linux-gnu-c-debug/conf/configure.log to
> petsc-maint at mcs.anl.gov
> make: [all] Error 1 (ignored)
For the record, here are the commands I used to install:
> hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
> cd petsc-dev/config
> hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
> cd ..
> export PETSC_ARCH=arch-linux-gnu-c-debug
> export PETSC_DIR=$PWD
> ./configure --with-cc=mpicc --with-fc=mpif90
> --download-f-blas-lapack=1 --download-hdf5=1
> --prefix=$PETSC_DIR/$PETSC_ARCH
> make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug all
> make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug install
> cd ..
I'm not sending it to thepetsc-maint list yet, in case you can figure
out the fix right away.
             Carl Ponder, Ph.D.
             NVidia
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/d17237c1/attachment.html>
