[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 14:56:13 CDT 2010
*On 11/03/2010 01:33 PM, Satish Balay wrote:*
>     for http there is no '$USER:$PASSWORD@' in the URL [I guess its just ignored - so it works..]
>     I pushed a fix now.. You can pull and retry [after 'hg revert configure' - to remove your local changes]
Satish -- thanks -- it works now.
Is thepetsc-dev stable enough to update on-the-fly like this, or do you
have release versions we should we be using?
     -- Carl Ponder
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/e1037906/attachment.html>
