[petsc-dev] mecurial emergency
Sat Jun 26 18:05:06 CDT 2010
Is this fixed? Can someone mail when it is over?
For post mortem, how did this happen? The only way I can
think of is that
  a) Someone forced a push (never never never to this)
  b) Someone pulled into a repo that already had multiple heads
  c) Someone checked in a changset in the middle of a merge
   Matt
On Sat, Jun 26, 2010 at 11:19 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sat, 26 Jun 2010, Satish Balay wrote:
> > On Sat, 26 Jun 2010, Barry Smith wrote:
> > >   I need help. FAQ.html has "instructions" to fix this but the
> instructions are not complete enough: they say
> > > "Fixing this is complicated. Basically, you clone the repo
> > > before you made head #2, then create the diff for the bad changeset
> > > that made head #2. Apply it to the clone and checkin, then pull the
> > > master.
> > > Now
> > > 1) how do I clone the repo before you made head #2?
> > > 2) how do you create the diff for the bad changeset that made head # 2
> > > 3) how do you apply it to the clone
> > > 4) how do you checkin? Never heard of checkin in mecurial
> > > Please let me know this and I will also update the FAQ.
> > > [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg merge
> > > abort: outstanding uncommitted changes (use 'hg status' to list
> changes)
> > > [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg commit
> > > nothing changed
> > > [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg status |
> head -5
> > > ! src/ksp/ksp/examples/tutorials/ex1.c
> > Looks like some files are deleted. Commit doesn't pick it up
> > automatically. [unless 'hg rm' is used for the deletion]
> > > ? #configure.log#
> > > ? arch-g++.py
> > > ? bin/#petscrun#
> > > [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg heads
> > > changeset:   16298:503f0f312436
> > > tag:         tip
> > > parent:      16297:53f17d50e2f2
> > > parent:      16296:90b6abac8d23
> > > user:        Victor Minden victorminden at gmail.com
> > > date:        Fri Jun 25 15:25:05 2010 -0500
> > > description:
> > > commit after merge
> > > changeset:   16291:47055b889013
> > > user:        Barry Smith bsmith at mcs.anl.gov
> > > date:        Sat Jun 26 09:54:02 2010 -0500
> > > files:       src/docs/website/documentation/codemanagement.html
> src/docs/website/documentation/linearsolvertable.html
> src/docs/website/features/index.html
> src/docs/website/miscellaneous/acknwldg.html
> src/docs/website/miscellaneous/funding.html src/sys/makefile
> src/sys/totalview/makefile src/sys/totalview/tv_data_display.c
> src/sys/totalview/tv_data_display.h
> > > description:
> > > minor cleanup of docs
> > > added totalview include and source for debugger
> > I would do:
> > hg update -C 47055b889013
> > hg merge
> > hg commit
> I should have added: the above instructions are for the case where
> local changes can be discarded. If I have to preserve the local
> changes [depending upon how the changes were done] - I might use some
> different process.
> The following might work for almost all cases [since the merge is
> interfering with the local changes - do the merge in a different/clean
> repo]
> i.e:
> hg clone -r 47055b889013 petsc-dev petsc-dev-merge
> cd petsc-dev-merge
> hg pull [tip]
> hg merge
> hg commit
> hg push [../petsc-dev]
> cd ../petsc-dev
> hg status
> hg update or 'hg commit/hg merge' or somethig suitable for commiting local
> changes and merging
> local changes
> hg push [petsc.cs.iit.edu]
> Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100627/1066179b/attachment.html>
