[petsc-dev] mecurial emergency
Sat Jun 26 10:13:08 CDT 2010
On Sat, 26 Jun 2010, Barry Smith wrote:
>   I need help. FAQ.html has "instructions" to fix this but the instructions are not complete enough: they say
> "Fixing this is complicated. Basically, you clone the repo
> before you made head #2, then create the diff for the bad changeset
> that made head #2. Apply it to the clone and checkin, then pull the
> master.
> Now
> 1) how do I clone the repo before you made head #2?
> 2) how do you create the diff for the bad changeset that made head # 2
> 3) how do you apply it to the clone
> 4) how do you checkin? Never heard of checkin in mecurial
> Please let me know this and I will also update the FAQ.
> [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg merge
> abort: outstanding uncommitted changes (use 'hg status' to list changes)
> [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg commit
> nothing changed
> [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg status | head -5
> ! src/ksp/ksp/examples/tutorials/ex1.c
Looks like some files are deleted. Commit doesn't pick it up
automatically. [unless 'hg rm' is used for the deletion]
> ? #configure.log#
> ? arch-g++.py
> ? bin/#petscrun#
> [barry-smiths-macbook-pro:src/sys/totalview] barrysmith% hg heads
> changeset:   16298:503f0f312436
> tag:         tip
> parent:      16297:53f17d50e2f2
> parent:      16296:90b6abac8d23
> user:        Victor Minden victorminden at gmail.com
> date:        Fri Jun 25 15:25:05 2010 -0500
> description:
> commit after merge
> changeset:   16291:47055b889013
> user:        Barry Smith bsmith at mcs.anl.gov
> date:        Sat Jun 26 09:54:02 2010 -0500
> files:       src/docs/website/documentation/codemanagement.html src/docs/website/documentation/linearsolvertable.html src/docs/website/features/index.html src/docs/website/miscellaneous/acknwldg.html src/docs/website/miscellaneous/funding.html src/sys/makefile src/sys/totalview/makefile src/sys/totalview/tv_data_display.c src/sys/totalview/tv_data_display.h
> description:
> minor cleanup of docs
> added totalview include and source for debugger
I would do:
hg update -C 47055b889013
hg merge
hg commit
Satish
