[petsc-dev] Problem in VecAXPY
Wed Jun 16 10:54:09 CDT 2010
That cannot be right because this check was added two days ago.
   Matt
On Wed, Jun 16, 2010 at 10:40 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 16 June 2010 11:38, Matthew Knepley <knepley at gmail.com> wrote:
>> Barry,
>>   You inserted a check in VecAXPY:563 (which Jed corrected)
>>  jed at 16195<http://petsc/petsc-dev/annotate/c5b7ef1f9e2d/src/vec/vec/interface/rvector.c#l563>
>>    563 <#129416afbe1f4061_1294132b5614bbcc_l563>
>>   if (x == y) SETERRQ(((PetscObject)x)->comm,PETSC_ERR_ARG_IDN,"x and y cannot be the same vector");
>> However, this seems to make no sense in light of mg.c:53
>>     ierr =
>> MatInterpolateAdd(mglevels->interpolate,mgc->x,mglevels->x,mglevels->x);CHKERRQ(ierr);
>> which will eventually call this with y == w, and has stack
>> 0]PETSC ERROR: VecAXPY() line 563 in src/vec/vec/interface/rvector.c
>> [0]PETSC ERROR: MatMultAdd_ML() line 179 in src/ksp/pc/impls/ml/ml.c
>> [0]PETSC ERROR: MatMultAdd() line 2041 in src/mat/interface/matrix.c
>> [0]PETSC ERROR: MatInterpolateAdd() line 6535 in
>> [0]PETSC ERROR: PCMGMCycle_Private() line 53 in src/ksp/pc/impls/mg/mg.c
>> [0]PETSC ERROR: PCMGMCycle_Private() line 50 in src/ksp/pc/impls/mg/mg.c
>> [0]PETSC ERROR: PCApply_MG() line 288 in src/ksp/pc/impls/mg/mg.c
>> [0]PETSC ERROR: PCApply() line 358 in src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: KSPSolve_PREONLY() line 27 in
>> src/ksp/ksp/impls/preonly/preonly.c
>> [0]PETSC ERROR: KSPSolve() line 427 in src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: PCApply_FieldSplit() line 530 in
>> src/ksp/pc/impls/fieldsplit/fieldsplit.c
>> [0]PETSC ERROR: KSPInitialResidual() line 65 in
>> src/ksp/ksp/interface/itres.c
>> [0]PETSC ERROR: KSPSolve_GMRES() line 236 in
>> src/ksp/ksp/impls/gmres/gmres.c
>> Can I remove this check?
>>   Thanks,
>>       Matt
>> experiments lead.
>> -- Norbert Wiener
> I think x==y have to be special-cased (potential issues with arg aliasing
> in BLAS?). What about:  if (x==y) VecScale(x, 1+alpha)
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100616/ce383d2f/attachment.html>
