[petsc-dev] BuildSystem failure
Lisandro Dalcin dalcinl at gmail.com
Wed Jun 2 18:03:18 CDT 2010
Still not sure why I've reached that failing code (running on
VirtualBox'ed Linux), but as isIntel(compiler) is a staticmethod, the
call self.isIntel() looks wrong.
             Configuring PETSc to compile on your system
TESTING: checkCCompiler from
config.setCompilers(config/BuildSystem/config/setCo*******************************************************************************
                ERROR in COMMAND LINE ARGUMENT to ./configure
isIntel() takes exactly 1 argument (0 given)
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
