[petsc-dev] nightly configure failures
Matthew Knepley
knepley at gmail.com
Tue Jun 1 16:54:42 CDT 2010
Fixed and pushed.
Matt
On Wed, Jun 2, 2010 at 4:04 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> ./config/configure.py --with-mpi-dir=/home/buildbot/install/x86_linux_single_nosched_binbot --with-debugging=no --with-fortran=no --with-sieve=1 --with-clanguage=C++ --with-mpi=1 --with-boost=1 --with-chaco=1 --download-boost=ifneeded --download-chaco=1 --with-x=0 --with-shared=1 --CXXFLAGS=-DNEW_SECTION
> in dir /home/buildbot/slave/build/x86_linux_single_nosched_binbot/PETSc/dev/binaries-926 (timeout 3600 secs)
> watching logfiles {'configure.log': 'configure.log'}
> argv: ['./config/configure.py', '--with-mpi-dir=/home/buildbot/install/x86_linux_single_nosched_binbot', '--with-debugging=no', '--with-fortran=no', '--with-sieve=1', '--with-clanguage=C++', '--with-mpi=1', '--with-boost=1', '--with-chaco=1', '--download-boost=ifneeded', '--download-chaco=1', '--with-x=0', '--with-shared=1', '--CXXFLAGS=-DNEW_SECTION']
> environment: {'CC': 'mpicc', 'PYTHONPATH': '/home/buildbot/install/x86_linux_single_nosched_binbot/lib/python2.3/site-packages:/home/buildbot/lib/python2.3/site-packages', 'SSH_CLIENT': '24.205.74.185 46384 22', 'WORKDIR': '/home/buildbot/slave/build/x86_linux_single_nosched_binbot/PETSc/dev/binaries-926', 'LOGNAME': 'buildbot', 'USER': 'buildbot', 'PYTHON': 'python2.3', 'HOME': '/home/buildbot', 'PREFIX': '/home/buildbot/install/x86_linux_single_nosched_binbot', 'PATH': '/home/buildbot/install/x86_linux_single_nosched_binbot/bin:/home/buildbot/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games', 'F77': 'mpif77', 'LD_LIBRARY_PATH': '/home/buildbot/install/x86_linux_single_nosched_binbot/lib:/home/buildbot/install/x86_linux_single_nosched_binbot/opt/petsc-dev/linux-gnu-cxx-opt/lib', '_': '/home/buildbot/opt/python2.3/bin/python2.3', 'SSH_CONNECTION': '24.205.74.185 46384 131.215.144.165 22', 'LANG': 'en_US.UTF-8', 'TERM': 'xterm', 'SHELL': '/bin/bash', 'SHLVL': '1', 'SSH_TTY': '/dev/pts/0', 'PETSC_ARCH': 'linux-gnu-cxx-opt', 'CXX': 'mpicxx', 'PWD': '/home/buildbot', 'FC': 'mpif90', 'PETSC_DIR': '/home/buildbot/slave/build/x86_linux_single_nosched_binbot/PETSc/dev/binaries-926', 'HDF5_HOME': '/home/buildbot/install/x86_linux_single_nosched_binbot', 'MAIL': '/var/mail/buildbot', 'LS_COLORS': 'no=00:fi=00:di=01;34:ln=01;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.svgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:'}===============================================================================
> Configuring PETSc to compile on your system
> CONFIGURATION CRASH (Please send configure.log to petsc-maint at mcs.anl.gov)
> invalid syntax (Configure.py, line 404)
> File "./config/configure.py", line 254, in petsc_configure
> framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:], loadArgDB = 0)
> File "/home/buildbot/slave/build/x86_linux_single_nosched_binbot/PETSc/dev/binaries-926/config/BuildSystem/config/framework.py", line 105, in __init__
> self.createChildren()
> File "/home/buildbot/slave/build/x86_linux_single_nosched_binbot/PETSc/dev/binaries-926/config/BuildSystem/config/framework.py", line 340, in createChildren
> self.getChild(moduleName)
> File "/home/buildbot/slave/build/x86_linux_single_nosched_binbot/PETSc/dev/binaries-926/config/BuildSystem/config/framework.py", line 298, in getChild
> type = __import__(moduleName, globals(), locals(), ['Configure']).Configure
> Traceback (most recent call last):
> File "./config/configure.py", line 339, in ?
> petsc_configure([])
> File "./config/configure.py", line 335, in petsc_configure
> close(framework.log)
> NameError: global name 'close' is not definedprogram finished with exit code 1
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100602/d95ed1db/attachment.html>
