[petsc-dev] CMake proof of concept
Tue Jun 1 13:44:06 CDT 2010
On Jun 1, 2010, at 4:57 AM, Jed Brown wrote:
> On Mon, 31 May 2010 19:13:07 -0500, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   You have an awful lot of confidence in cmake. I have no problem at
>> all setting up a system where PETSc can use cmake, that's great. But I
>> don't want PETSc to ever be in a position of not being able to do
>> something because kitware/whatever decided that they no longer or
>> would not supported xyz or we have to wait six months for them to
>> "port" to a "new system".
> This is legitimate and obscure hardware/compilers is a big reason why
> CMake has no business being the only build system for PETSc.  Given
> make's failings on Windows or whatever, maybe builder.py will be able to
> fill the role of canonical build system.
> But in the world of IDE integration, I think they are way ahead because
> quite a number of IDEs have written explicit support for CMake, in the
> sense that you just point it to the project root and a set of build
> directories and automatically get proper source analysis (including
> correct macro expansion when you switch "PETSC_ARCH" from the menu), all
> the relevant build targets, debug profiles, etc.  Since most IDEs have
> already "bought in", I think it is a reasonable language for talking to
> them, and suspect that direct PETSc/BuildSystem -> IDE-X links will be
> unnecessary.
   Cool. I guess you need to stick your previous email into the appropriate documentation in PETSc. Would this be in the users manual, a separate web-age, something else? Then a couple of us can be guinea pigs and try to use it with xcode and eclipse.
   Barry
> Jed
