[petsc-dev] control configure summary output
Thu Jan 28 18:22:12 CST 2010
On Thu, Jan 28, 2010 at 5:43 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Matt,
> currently configure dumps the following to the screen
> Compilers:
>  C Compiler:         /home/balay/soft/linux64/mpich2-1.1/bin/mpicc  -fPIC
> -Wall -Wwrite-strings -Wno-strict-aliasing -g3
>  Fortran Compiler:   /home/balay/soft/linux64/mpich2-1.1/bin/mpif90  -fPIC
> -Wall -Wno-unused-variable -g
> Linkers:
>  Shared linker:   /home/balay/soft/linux64/mpich2-1.1/bin/mpicc  -shared
>  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -g3
>  Dynamic linker:   /home/balay/soft/linux64/mpich2-1.1/bin/mpicc  -shared
> PETSc:
>  ** Before running "make" your PETSC_ARCH must be specified with:
>  **  ** setenv PETSC_ARCH asterix-foo (csh/tcsh)
>  **  ** PETSC_ARCH=asterix-foo; export PETSC_ARCH (sh/bash)
>  ** Before running "make" your PETSC_DIR must be specified with:
>  **  ** setenv PETSC_DIR /home/balay/tmp/petsc-dev (csh/tcsh)
>  **  ** PETSC_DIR=/home/balay/tmp/petsc-dev; export PETSC_DIR (sh/bash)
>  ** Now build the libraries with "make all"
>  Clanguage: C
>  Scalar type: real
> MPI:
>  Includes: -I/home/balay/soft/linux64/mpich2-1.1/include
> X11:
>  Includes:
>  Library:  -lX11
>  PETSc shared libraries: enabled
>  PETSc dynamic libraries: disabled
>  Memory alignment:16
> BLAS/LAPACK: -llapack -lblas
> Its a bit wildy - and some of the recommendations get missed out. I'd like
> to to read something like:
> Compilers:
> Linkers:
> PETSc:
>  PETSC_DIR: /home/balay/tmp/petsc-dev
>  PETSC_ARCH: asterix-foo
>  Clanguage: C
>  Scalar type: real
>  Memory alignment:16
> MPI:
> X11:
>  Includes:
>  Library:  -lX11
> Or simplify the last section to:
>  ** Now build the libraries with "make PETSC_ARCH=asterix-foo
> PETSC_DIR=/home/balay/tmp/petsc-dev all"
> Is there a way to control the order in which this stuff is dumped to
> the screen [from the various .py files - so that it goes into the same
> 'PETSc:' section?]
This output happens in config.Framework.cleanup() and all it does is call
str() on
each guy. If you really want finer control over this output, meaning
concatenation into
higher level groups (above the module level), then you should
  a) change to another function like banner() which returns with a group
name
  b) change this loop to first group up output and then logWrite() it
However, its not clear to me that we need this. Rather, we might get away
with just
having PETSc.Configure() give this overall advice at the end.
What do you think?
  Matt
> thanks,
> satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100128/a4fb48e9/attachment.html>
