[petsc-dev] Petsc-dev compilation: error because of underscore.
Tue Jan 26 22:51:44 CST 2010
On Jan 26, 2010, at 6:41 PM, Satish Balay wrote:
> The following change gets configure going.
> But I think Barry is looking at a different fix.. [if not - I can
> push this]
    DAMN STRAIGHT I AM looking for something different. I am looking
for the correct fix, not some ugly crap hack and terrible inconsistent
user interface!
    Here is the issue: When providing an option (not capitalized, like
the autoconf style "environmental variables" AR_FLAGS), for example --
with-batch, how does one represent SPACES in the option name. We chose
(actually Matt chose) to represent it with a -
    Because of "how the python code happened to be written" this rule
was violated with the options --with-sizeof_int --with-
sizeof_long_long --with-sizeof_void_p. It was not violated for a good
user interface reason but simply because Matt happened to write the
code that generated the strings this way.
    When I discovered this inconsistent (for no reason) usage I tried
to fix it. I fixed the _ after sizeof_ and partially fixed the _ in
the other blank but missed its generation with the batch command. This
is why things broke with with the --with-batch option.
    I have tried to fixed this again by removing these invalid
"exceptions" from petsc-dev and handling the " " correctly in
BuildSystem; so everyone please hg update BOTH! Please let me know if
something is still broken so I can fix it.
   Why do I make such a big deal about this? If the rule is ALWAYS
replace " " in option strings with - this is easy to remember and use.
If the rule is almost always replace " " with - except in a few
special cases that you just have to happen to know, this is an insane
rule.
    Barry
Notes: one could argue that to be consistent with the CAPS_OPTIONS we
should always use _ even in the --with_xx options. This is
inconsistent with autoconf that uses --with-xx so which consistency
should we match? I find the - more attractive and dislike the
CAPS_OPTIONS so am happy with the way it is, but am open to changing it.
What about --with-sizeof-size_t, how come that has an underscore? It
has an underscore because the type name has an underscore, it does not
come from applying a replace " " with _.
> Satish
> -      for exc in ['superlu_dist', 'PETSC_ARCH', 'PETSC_DIR',
> 'CXX_CXXFLAGS', 'LD_SHARED', 'CC_LINKER_FLAGS', 'CXX_LINKER_FLAGS',
> 'FC_LINKER_FLAGS', 'AR_FLAGS', 'C_VERSION', 'CXX_VERSION',
> 'FC_VERSION','qd_dd', 'void_p']:
> +      for exc in ['superlu_dist', 'PETSC_ARCH', 'PETSC_DIR',
> 'FC_VERSION','qd_dd', 'known-sizeof-void_p','known-sizeof-
> long_long','known-sizeof-size_t']:
> On Tue, 26 Jan 2010, Matthew Knepley wrote:
>> Ah, will you make a list or should i?
>>  Matt
>>> All can run with '--with-batch=1' on their machines to reproduce the
>>> problem. [and see if their fixes fix it or not]
>>> Satish
