[petsc-dev] Petsc-dev compilation: error because of underscore.
Tue Jan 26 18:43:10 CST 2010
On Tue, Jan 26, 2010 at 6:41 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> The following change gets configure going.
> But I think Barry is looking at a different fix.. [if not - I can push
> this]
> Satish
> -      for exc in ['superlu_dist', 'PETSC_ARCH', 'PETSC_DIR',
> 'CXX_CXXFLAGS', 'LD_SHARED', 'CC_LINKER_FLAGS', 'CXX_LINKER_FLAGS',
> 'FC_LINKER_FLAGS', 'AR_FLAGS', 'C_VERSION', 'CXX_VERSION',
> 'FC_VERSION','qd_dd', 'void_p']:
> +      for exc in ['superlu_dist', 'PETSC_ARCH', 'PETSC_DIR',
> 'known-sizeof-void_p','known-sizeof-long_long','known-sizeof-size_t']:
Just use void_p, long_long, size_t since it does a find().
  Matt
> On Tue, 26 Jan 2010, Matthew Knepley wrote:
> > Ah, will you make a list or should i?
> >   Matt
> > > All can run with '--with-batch=1' on their machines to reproduce the
> > > problem. [and see if their fixes fix it or not]
> > > Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100126/8d08c895/attachment.html>
